7 years, 3 months ago.
Sending AT commands to bluetooth module using ATCmdParser
I am using a NUCLEO L432KC to send AT commands to a bluetooth classic module to change the default baud rate. I want to use the ATCmdParser to send AT commands to the bluetooth module, but I get the following error: Error: Identifier "ATCmdParser" is undefined. Please help!
Serial pc(PA_2, PA_15);
Serial bt(PA_9, PA_10);
ATCmdParser at(&bt, "\r\n")
at.send("AT") && at.recv("OK");
at.send("AT+AB ChangeDefaultBaud [921600]", 3) && at.recv("OK");*/
    pc.baud(921600);
    bt.baud(921600);
        wait(2);
        pc.printf("hello\n");
        bt.printf("hello\n");
mbed.h has include for ATCmdParser so that's not the problem. Issue is that you running the code outside of the main and ATCmdParser line is missing ';' Also loose the '*/' at the end of the second at.send(...)...
This seems to compile fine:
ATCmdParser at(&bt, "\r\n");
    pc.baud(921600);
    bt.baud(921600);
        wait(2);
In second at.send command you don't need ', 3' as you are don't have %d where to put that.
posted by Teppo Järvelin 14 Dec 2018
Hi Jihong,
We have edited your post so that it is more legible. In the future please use <<code>> and <</code>> tags as described in the "Editing tips".
It appears that you are missing a #include of "platform\ATCmdParser.h". We have a AT command parser example here:
Ralph, Team Mbed
