7 years, 4 months ago.
Thread question
I am using a B-L475E-IO1A1 and I am trying to use Threads. I checked the MBed platform site and it says that my board uses OS5 which, as far as I understand, should have the ROTS libraries included (correct me if I am wrong)
However, when I try something like this (as per the OS5 documentation):
<<code>>#
AnalogIn ain(A1);
void myFunction(){
printf("%in", ain);
int main{ Thread thread; thread.start(myFunction ); } <</code>>
it gives me an error that Thread is not identified.
Then I downloaed the mbed-rtos library and included it in my project. It then allowed me to compile and burn my program on my board. However, nothing gets printed either. Anyone has any ideas? I am confused if I need to actual include the rtos library or if it's actually included. If it were, why did I get that Thread error to start with? Also the compiler keeps crushing and I am not sure if it's my connection, heavy code or just the compiler itself.
Any helps is appreciated.
You not need import RTOS lib when you use MbedOS5 lib.
Your code
// missing #include "mbed.h"
/*Thread thread;*/ //probably correct place
AnalogIn ain(A1);
void myFunction(){
printf("%in", ain); //probably you need to declare Serial and something more in parameters
int main{ // missing ()
Thread thread; //probably wrong place
thread.start(myFunction);
so...
Try this
DigitalOut led1(LED1);
AnalogIn ain(A1);
Serial pc(USBTX, USBRX);
Thread thread;
void myFunction(){
//while(1){
pc.printf("Input: %f", ain.read());
//wait(0.5);
int main(){
pc.printf("Running…\n");
while(true){
led1 =! led1;
wait(0.5);
//while (osWaitForever);
gl hf
Hello. To enable rtos just with mbed.h include my solution is open rtos blink example and then modify it.
posted by Kamil M 17 Nov 2018
