7 years, 4 months ago.
What' the pin should connect if I use UART1?
i defined two pins in the LPC1768 as the following code shows:
LPC_PINCON->PINSEL0|=(1<<30); define P0.15 as TXD1.
LPC_PINCON->PINSEL1|=(1<<0); define P0.16 as RXD1.
I know in Lpc1768 FBD 100 this two pins is 62 and 63.
however in the Mbed Lpc 1768 which has 40 pins, which two pins should I connect? P15 and P16? The picture of Mbed Lpc 1768 is showing?
p13 and p14.
The board schematic is here: https://os.mbed.com/media/uploads/chris/mbed-005.1.pdf
On page 3 on the right hand side you can see that P0.15 connected to a signal called DIP13 which on page 5 then connects to pin 13 on the board outline.
