7 years, 4 months ago.
I can't compile the cog with any existing programs
Hi, When i attempt to target any existing programs in my online compiler, i get the following error.
Error: Target "EV_COG_AD3029LZ" is not recognized
I have removed the cog board from my list of available targets and put it back again, i have updated all files and i have used different browsers - they all give the same result -
Take an existing program previously working with a different Mbed board and try to target the cog - it always give the error Error: Target "EV_COG_AD3029LZ" is not recognized
However, if i import a new program into the online compiler - it works.
7 years, 3 months ago.
Hi Sean,
We're able to build existing projects just fine for the EV_COG_AD3029LZ. However, the support for this target is relatively new and only supports Mbed OS v5.6 and later.
Could you please check that you aren't trying to build a project based on Mbed OS v5.5 or earlier or even an OS2 project?
If you have an older Mbed OS5 project, you can readily update the Mbed version by right-clicking on your project in the Program Workspace and selecting "Update". You won't be able to migrate OS2 projects using the "Update" feature.
Ralph, Team Mbed
