12 years, 12 months ago.
PrintBuffer
Hi I have a problem with the following header file PrintBuffer.h in the MLX90620 library. It is not found.
Bit weird it is required to have that one, but if you import this one: https://mbed.org/users/loopsva/code/PrintBuffer/, in your project, it should work.
My Bad,
I guess I shouldn't have made the MLX90620 library dependent on the PrintBuffer. I used PrinfBuffer only for debugging at the time.
...kevin (aka loopsva)
