7 years, 5 months ago.
Error: Identifier "SerialHalfDuplex" is undefined in "AX12/AX12.h", Line: 183, Col: 6
I am having this error message when compiling the program. Error: Identifier "SerialHalfDuplex" is undefined in "AX12/AX12.h", Line: 183, Col: 6 How should I fix it?
6 years, 4 months ago.
Yeah, looks like they just removed the half duplex library without offering a replacement or alternative. The serial library offered only supports duplex and simplex, so far as the documentation seems to indicate.
So Serial is not a valid replacement.
Hi there,
This error is because the Mbed OS 2 library no longer has a class named SerialHalfDuplex, in order to successfully compile your program please update your Mbed 2 library to the latest version by right-clicking on mbed and selecting "Update...". Then go into the AX12.h header file and replace line 183 with the following code:
Serial _ax12;
- Jenny, team Mbed
7 years, 1 month ago.
Hello Jenny, I tried doing the modification you suggested. The code is compiling but the motor isn't moving.
I'm using a Nucleo-F303RE I use the Example code with the only modification being the pins : AX12 myax12 (D9, D10, 1); I also tried : AX12 myax12 (D9, D10, 1); AX12 myax12 (USBTX, USBRX, 1); and AX12 myax12 (USBRX, USBTX, 1); I triple checked the wiring and its correct Would you have any idea as to why ?
