7 years, 5 months ago.
TCPSocket client.close() causes hardware fault.
Yesterday I received the MBED OS 5.10.1 available newsletter, in that newsletter it is said that an issue regarding client.accept() returning a NULL pointer was solved in the current MBED OS release.
I had some problems a few weeks ago regarding this so naturally I had to try ... You'll find the code I've written below.
EthernetInterface iface;
//TCPServer server;
TCPSocket server;
TCPSocket *client;
SocketAddress clientAddress;
int main (void)
     iface.connect();
    pc.printf("\n\nServer IP Address is %s\n", iface.get_ip_address());
    server.open(&iface);
    server.bind(SERVER_PORT);
    server.listen(10);
    while (true) {
         pc.printf("Server bound and listening\n");
        // server.accept(&client, &clientAddress);
        client = server.accept();
        char    buffer[1024];
        int     n = client->recvfrom(&clientAddress, buffer, sizeof(buffer));
        pc.printf("Connection succeeded!\nClient local stack address: 0x%08X\nClient's IP address: %s:%d\n\n", client,
                     clientAddress.get_ip_address(), clientAddress.get_port());
        pc.printf("Received %u bytes from remote host\n", n);  //print received message to terminal
        buffer[n] = NULL;
        pc.printf("Received message from Client :'%s'\n", buffer);
        pc.printf("Sending echo to client\n");
        client->send(buffer, n);
        client->close();
The software implements a simple TCPSocket echo server and produces the output below.
Server IP Address is 192.168.1.15
Client local stack address: 0x100032C0
Client's IP address: 192.168.1.8:51486
Received 10 bytes from remote host
Received message from Client :'Hallo MBED'
++ MbedOS Fault Handler ++
FaultType: HardFault
Context:
R0   : 000063A1
R1   : 100029C8
R2   : 10001474
R3   : 00000001
R4   : 00000002
R5   : 000063A1
R6   : 00000000
R7   : 00000000
R8   : 100025A8
R9   : 0000C91E
R10  : 00000000
R11  : 00000000
R12  : 10000B68
SP   : 10007FB0
LR   : 00012C73
PC   : 0000FE78
xPSR : 21001C0B
PSP  : 10001470
MSP  : 10007F90
CPUID: 412FC230
HFSR : 40000000
MMFSR: 00000000
BFSR : 00000004
UFSR : 00000000
DFSR : 0000000A
AFSR : 00000000
Mode : Handler
Priv : Privileged
Stack: MSP
-- MbedOS Fault Handler --
++ MbedOS Error Info ++
Error Status: 0x80FF013D Code: 317 Module: 255
Error Message: Fault exception
Error Value: 0xFE78
Current Thread: Id: 0x100029C8 Entry: 0xDACB StackSize: 0x1000 StackMem: 0x100019C8 SP: 0x10007F48
For more info, visit: https://armmbed.github.io/mbedos-error/?error=0x80FF013D
-- MbedOS Error Info --
My TCP client application received the echo ... so the line that generated the MBedOS Error must certainly be client->close(). Am I doing something wrong?
Kind regards,
Koen
