7 years, 6 months ago.
Error: The build system did not finish successfully.
Hello! recently, I am working with HRM1017 (https://os.mbed.com/platforms/mbed-HRM1017/), while I used online-complier to compile the code last week. An issue "Error: The build system did not finish successfully." but the code can be compiled before last week and even the blinky example code cannot work. Also, I have tried the offline compiler mbed-cli. I have faced this issue (https://github.com/ARMmbed/mbed-cli/issues/698) when working the mbed os2. If there have another solution to deal with my problems? thank you!
Hi Chen,
We are aware of the issue with the online compiler and Mbed 2 targets and are currently working on a fix. In the meantime, you can also use the offline Mbed CLI to compile for the HRM1017, a quick start guide for the Mbed CLI is available here: https://os.mbed.com/docs/latest/tutorials/quick-start-offline.html & an easy installation guide is available here: https://os.mbed.com/docs/latest/tools/installation-and-setup.html
- Jenny, team Mbed
