7 years, 5 months ago.
How can I get the TCPSocketserver to work?
Hi i can't seem to get a simple socket server to work:
This is my code:
#define SERVER_PORT   80
EthernetInterface iface;
TCPSocket server;
Socket *client;
int main (void) {
    iface.connect();
    printf("\nServer IP Address is %s\n\r", iface.get_ip_address());
    server.open(&iface);
    server.bind(SERVER_PORT);
    server.listen();
    while (true) {
        printf("Server bound and listening\n");
        while (true) {
            client = server.accept();
            printf("Client connected, stack at 0x%08lX\n", client);
            char buffer[1024];
            int n; //= client->recv(buffer, sizeof(buffer));
            printf("Received %u bytes from remote host\n", n);
            // print received message to terminal
            // buffer[n] = '\0';
            // printf("Received message from Client :'%s'\n",buffer);
            //client->close();
The server does accept a connection from the remote host but the pointer to the client is a NULL pointer. I've been pulling my few remaining hears for about a day now ... Can someone please give me some pointers?
Kind regards,
Koen.
I also have this problem. Did you find a solution?
posted by Nikolai Zimfer 10 Nov 2018
If you update the mbed os at least the accept () function works. But last time I checked close() caused a run time error.
posted by Koen Kempeneers 10 Nov 2018
Hello Koen,
I hope that the following code will save your hair:
#include "TCPServer.h"
#include "TCPSocket.h"
TCPServer           server;
TCPSocket           client;
SocketAddress       clientAddress;
int main(void)
    iface.connect();
    server.bind(iface.get_ip_address(), SERVER_PORT);
    server.listen(5);
    while (true) {
        while (true) {
            server.accept(&client, &clientAddress);
            printf("Connection succeeded!\n\rClient's IP address: %s\n\r", clientAddress.get_ip_address());
            char    buffer[1024];
            int     n = client.recv(buffer, sizeof(buffer));
            printf("Received %u bytes from remote host\n", n);  //print received message to terminal
            buffer[n] = '\0';
            printf("Received message from Client :'%s'\n", buffer);
            client.close();
Thanks ! That works, but I get two warning messages from the compiler (mbed online compiler using mbed-os);
Warning: Function "TCPServer::TCPServer()" (declared at line 39 of "/extras/mbed-os.lib/features/netsocket/TCPServer.h") was declared "deprecated" in "TCPSocketServer.cpp", Line: 9, Col: 12
Warning: Function "TCPServer::accept(TCPSocket *, SocketAddress *)" (declared at line 81 of "/extras/mbed-os.lib/features/netsocket/TCPServer.h") was declared "deprecated" in "TCPSocketServer.cpp", Line: 23, Col: 21
Can you point me the correct manual pages ? I found this: obviously wrong article. https://os.mbed.com/docs/v5.10/mbed-os-api-doxy/class_t_c_p_socket.html#ac7d02ef109d2d3a48b6dcaa38869de80
Also ... How do you paste the code legible in the forum? The <<code>> <</code>> tags do not seem to work.
Thanks for your help.
posted by Koen Kempeneers 30 Sep 2018
  • It seems that something is wrong with the new network API :(
    Luckily the depricated one still works well :-)
  • To make code formattig work try to put the <<code>> <</code>> tags on their own separate lines:
<<code>>
Text of your code
<</code>>
posted by Zoltan Hudak 30 Sep 2018
