7 years, 6 months ago.
Ublox easy-connect and mbed OS 5.10.0
Just tried to update one of my projects to mbed OS 5.10.0 but then the compilation fails after giving lots of warning with this error:
[Error] NanostackRfPhyMcr20a.cpp@1713,7: class 'NanostackRfPhyMcr20a' does not have any field named '_irq_thread'
If I just create a new empty mbed project mbed new test Add easy-connect with mbed add https://os.mbed.com/teams/ublox/code/easy-connect/
toolchain GCC_ARM target ublox_c030_u201
Then when I compile it will fail
Development team for u-blox positioning and wireless products
Hi. I still really need some help here to be able to migrate to the ARM version. BR, Martin
posted by Martin Giebat 10 Oct 2018
Hi Martin,
Please try adding the Arm Mbed easy-connect library to your project instead of the u-blox one: mbed add https://github.com/ARMmbed/easy-connect
If you specifically need to use the CELLULAR_UBLOX network interface, I will see what needs to be done to update the Arm Mbed easy-connect library.
Please let me know how that goes & please let me know if you have any questions!
- Jenny, team Mbed
Hi Jenny, I am using the CELLULAR_UBLOX so help there would be highly appreciated.Was there a way for me to understand that I shouldn't use the UBLOX easy_connect? /Martin
posted by Martin Giebat 02 Oct 2018
Jenny,
I have a 2nd business case for support of u-blox (SARA-U201 module) via easy connect. Can you let me know the progress in understanding of the needed modifications to the ARM Mbed easy-connect library and the timeframe you would consider making the modifications available?
