7 years, 6 months ago.
How to use struct value in vector using classes
Hello, I need some help. if i have two classes class A and class B. Class A has a structure "input". for example
struct input
double kp ;
Class A
input *obj;
public:
A(input*)
now in A.cpp if i assign a value to kp then
this->obj->kp =0.3000;
and after that i want to use kp value in class B
now i creat B.h lets say in same namespace as i used in A, and in B.cpp i print out the value of kp it will come, but when i creat a vector of double and push_back kp then i don't get it value.
for example
    vector<double> *control;
   this->control->push_back(this->obj->kp);
   printf("the value of kp is %lf= \n", this->control[0]);  // and it gives 0.000000
but if i print out
printf("the value of kp is %lf= \n", this->obj->kp);                 // i will get the right value 0.30000
Can anyone please tell me my mistake. Thank you very much
Hello Ali,
  • It isn't quite clear for me where is class B defined and how can be a private member of class A (like obj) used within class B?
  • As Andy pointed out, control in your code is an uninitialized pointer pointing to some random location in the memory (there is no object of vector<double> type created in your code snippet to point to by control).
  • Since control is a pointer I do not understand how could an expression like this->control[0] compile? The control pointer must be dereferenced before using it, like (*this->control)[0].
A few advices:
  • To have a more readable code published here (on mbed pages) try to mark it up as below (with <<code>> and <</code>> tags, each on separate line at the begin and end of your code)
<<code>>
text of your code
<</code>>
  • All the containers in the standard library hold copies of the objects you place in them so your objects must be copy-constructible (have an accessible copy constructor) and assignable (have an accessible assignment operator).
  • You can ommit the this pointer inside a class definition, unless you need it to resolve an ambiguous situation.
An example which might be of help:
#include <iostream>
#include <vector>
using namespace std;
struct input
    double  kp;
class   A
public:
    input*              obj;
    vector<double>*     control;
    A(input* in, vector<double>* cont) : obj(in), control(cont) {
        obj->kp = 0.3;
        control->push_back(obj->kp);
        cout << "object of class A: (*control)[0] = " << (*control)[0] << endl;
class   B
public:
    B(vector<double>* cont) : control(cont) {
        cout << "object of class B: (*control)[0] = " << (*control)[0] << endl;
    input           in;
    vector<double>  ctrl;
    A               a(&in, &ctrl);
    B               b(&ctrl);
    cout << "a.obj->kp       = " << a.obj->kp << endl;
    cout << "(*a.control)[0] = " << (*a.control)[0] << endl;
    cout << "(*b.control)[0] = " << (*b.control)[0] << endl;
    return 0;
Below is the ouput:
object of class A: (*control)[0] = 0.3
object of class B: (*control)[0] = 0.3
a.obj->kp = 0.3
(*a.control)[0] = 0.3
(*b.control)[0] = 0.3
doesn't create a vector at any point, only a pointer to a vector. Try something more like
vector<double> control;
this->control.push_back(this->obj->kp);
Hi Andy
Thanks for your reply, but i think this makes no difference.
because if i write a value like
this->control->push_back(0.3000); it works fine
but if i used a struct value then it will show 0.00 in this->control[0]
posted by Ali Imran Siddiqui 06 Sep 2018
