7 years, 6 months ago.
mbed-http compile fail
The mbed-http library https://os.mbed.com/teams/sandbox/code/mbed-http/ fails when I try to use HTTPS. Specifically, https_request.h
HttpsRequest(NetworkInterface* net_iface,
const char* ssl_ca_pem,
http_method method,
const char* url,
Callback<void(const char *at, uint32_t length)> body_callback = 0)
results in "Undefined symbol mbed_ctr_drbg_free".
Are there configuration items that I am missing? Is there another HTTP library that supports HTTPS that is recommended?
Hi Peter,
You may be missing a few configuration items. Are you using the Mbed CLI or the online compiler? If you are using the Mbed CLI you can follow the steps below to create a new Mbed HTTPS project and build successfully (the following is also adapted from the http-example here):
mbed new https-examplecd https-examplembed add https://os.mbed.com/teams/sandbox/code/mbed-http/mbed add https://github.com/ArmMbed/easy-connect/- Create a
main.cppfile in your root project directory - Create a
mbed_app.jsonfile in your root project directory for the Easy Connect library - Copy/paste the contents of the HTTPS example program into your
main.cppfile: https://gist.github.com/yennster/ae97f2ebc14b836b4f531a2fc0470313 - Copy/paste the contents of the following file into your
mbed_app.jsonfile: https://gist.github.com/yennster/75933bef3fe94801917e6a3839faf31f - Within
mbed_app.jsonunder config > network-interface > value, replace "ETHERNET" with your board's network connectivity option - Now compile:
mbed compile -t <your toolchain> -m <your board>in my case I used the following command:mbed compile -t gcc_arm -m k64f - You should be able to compile successfully and now you can click and drag the created .bin file to your board
Then you can alter the main.cpp for your purposes!
- Jenny, team Mbed
I'm using the online compiler, but I followed the corresponding steps to create a new project. Still produces the same error.
posted by 05 Sep 2018Hi Peter, have you updated to the latest version of Mbed OS?
- Jenny, team Mbed
posted by 05 Sep 2018Which network interface are you using and which target board?
- Jenny, team Mbed
posted by 05 Sep 2018Hi, please try the following steps:
- Import the following example into your online compiler: https://os.mbed.com/teams/sandbox/code/http-example/
- Delete the easy-connect library from the http-example program and re-add it with the following URL:
https://github.com/ARMmbed/easy-connect/ - Right click on the mbed-os library and select "Update..."
- Change the network-interface in
mbed_app.jsonto "CELLULAR_ONBOARD" - In the
sourcefolder openselect-demo.hand change the#define DEMOto#define DEMO DEMO_HTTPS - Make sure you have selected the u-blox C027 target in the top right corner
- Then click "Compile" and you should successfully download the .bin file for the https example
Please let me know if this works for you!
- Jenny, team Mbed
posted by 05 Sep 2018The last set of instructions succeeds. How do I apply this to my code? I'm trying to use mbed-http without using easy-connect as I only want to use a cell modem and don't need all those other interfaces. I basically created my main.cpp by copying main-https.cpp from that same example project, then replaced
NetworkInterface* network = easy_connect(true);
with
network = CellularBase::get_default_instance();
Do I have to use easy-connect to make mbed-http work?
posted by 05 Sep 2018Hi again Peter,
Glad that succeeded for you. What I would recommend next is to investigate how the easy connect library implements the "CELLULAR_ONBOARD" connection present in the Mbed OS library. Specifically you'll want to implement the network connection code present in easy-connect.cpp.
- Jenny, team Mbed
posted by 05 Sep 2018I think that's what I did to figure out how to implement the cellular-only version in the first place. I'll examine that further, but two things to consider:
1. My code works perfectly fine if I use HttpRequest() from mbed-http. The compiler failure occurs with HttpsRequest(). 2. The error is a missing symbol which seems to be from tls_socket.h. There doesn't seem to be any relation with creating a cellular network instance.
