7 years, 8 months ago.
Fail to write to I2C after arbitrary amount of time
Hi, I am trying to write some code to read data over I2C. I have been successful in receiving data, and the program runs for a good amount of time (about 90 minutes on average) before the I2C write function returns NACK, and continues to do so after that.
The device I am using is a UBlox M8 module. I have the device rebooting once this error occurs (lines 22-27) and it works for now, but I'd really like to understand why this is happening.
I ran it over the weekend (about 60 hours) and it rebooted 36 times.
Thanks!
Minimal example
Serial serial(USBRX, USBTX, 19200);
I2C i2c(I2C_SDA, I2C_SCL);
const uint8_t slaveAddr = 0x42;
void read(void const *args) {
    I2C* i2c = (I2C*)args;
    char buf[128];
    Thread::wait(100);
    const char I2C_ADDR = slaveAddr << 1; // Address of I2C slave to read
    const char COUNT_REG[] = { 0xFD };   // Count register address - how many bytes are available to read
    const char DATA_REG[] = { 0xFF };    // Data register address - the data stream
    // Set read register to COUNT_REG to open I2C stream
    bool success = !i2c->write(I2C_ADDR, COUNT_REG, sizeof(COUNT_REG));
    while (success) {
        success = !i2c->write(I2C_ADDR, COUNT_REG, sizeof(COUNT_REG), true) &&
              !i2c->read(I2C_ADDR, buf, 2);
        if (!success) {
            serial.printf("Write/read failed...\r\n");
			Thread::wait(500);
			NVIC_SystemReset();
        int bytesAvailable = (unsigned short)(buf[0] << 8 | buf[1]);
        if (bytesAvailable) {
            serial.printf("\r\nbytesAvailable  %i\r\n", bytesAvailable);
            while (bytesAvailable && success) {
                int bytesToRead = (bytesAvailable < (unsigned) sizeof(buf)) ? bytesAvailable : sizeof(buf);
                success = !i2c->write(I2C_ADDR, DATA_REG, sizeof(DATA_REG), true) &&
                        !i2c->read(I2C_ADDR, buf, bytesToRead);
                if (success) {
                    for (int i = 0; i < bytesToRead; i++) {
                        serial.printf("%02X", buf[i]);
                    bytesAvailable -= bytesToRead;
                } else {
                    serial.printf("Couldn't read even though bytes available = %d\r\n", bytesAvailable);
            serial.printf("\r\n");
        Thread::wait(100);
	Thread readThread;
    readThread.start(callback(read, (void *)&i2c));
    while (1)
        led = !led;
        Thread::wait(500);
    return 0;
@team-ublox: could you please provide Steven with necessary information to debug the crash that he is observing on the Ublox device? Thanks!
posted by Naveen Kaje 20 Aug 2018
For @team-ublox reference, I am running a NINA-B112 connected to a SAM-M8Q-0-10
posted by Steven Crake 22 Aug 2018
The article you have shared here is very awesome. I really like and appreciate your work. The points you have mentioned in this article are useful. I must try to follow these points and also share others. http://happywheelsaz.com/
posted by happy wheels 24 Aug 2018
Assigned to u-blox 7 years, 8 months ago.
