7 years, 7 months ago.
Why is wait() different when using mbed and mbed-os libraries?
When using mbed library the wait() function works properly; for example when using blinky the time on and off of the LED is correct. However, when using the mbed-os library the wait function waits 10x as long. This was observed using an LPC1768
Hi Sandra,
The reason why mbed wait is faster than mbed-os is because mbed-os contain an RTOS while mbed is not. For >1ms waits, the thread can be preempted to save power in mbed-os. To fix it, you will need to put the time-sensitive code in a critical section.
critical section
core_util_critical_section_enter();
do_timing_thing();
wait(0.5);
core_util_critical_section_exit();
- Peter, team Mbed
