7 years, 7 months ago.
Cannot compile for RedBearLab Nano v2
Its shows while compiling blinky sketch:
Error: Cannot open source input file "device.h": No such file or directory in "extras/mbed-os/mbed-os.lib/hal/api/platform.h", Line: 19, Col: 21
Yes, Ive tried update libs
Hi there,
I am assuming you are using the offline Mbed CLI to compile Blinky for the RedBear BLENANO 2 as this board is not yet available in the online compiler.
Are you compiling the latest mbed-os-example-blinky (the Blinky example that uses the latest version of Mbed OS 5)?
I compile the above example using the following command in my terminal: mbed compile -t [toolchain] -m rblab_blenano2 and I am not able to replicate the error you are seeing. Can you please make sure you are using the correct version of Mbed? You can read about the differences between Mbed OS 2 and 5 here: https://os.mbed.com/docs/v5.9/tutorials/major-releases.html
- Jenny, team Mbed
