7 years, 8 months ago.
How can i solve these errors when reprogramming a MAXREFDES100?
I have tried to program MAXREFDES100# but I've encountered some errors when trying to compile the code. The main code looks like this
  1. include "mbed.h"
  2. include "MAX14720.h"
  3. include "MAX30205.h"
Define all I2C addresses
  1. define MAX30205_I2C_SLAVE_ADDR_TOP (0x92)
  2. define MAX30205_I2C_SLAVE_ADDR_BOTTOM (0x90)
  3. define I2C_ADDR_PMIC (0x54)
I2C Masters I2C i2c1(I2C1_SDA, I2C1_SCL); used by MAX30205 (1), MAX30205 (2), BMP280 I2C i2c2(I2C2_SDA, I2C2_SCL); used by MAX14720, MAX30101, LIS2DH
Top Local Temperature Sensor MAX30205 MAX30205_top(&i2c1, MAX30205_I2C_SLAVE_ADDR_TOP); Bottom Local Temperature Sensor MAX30205 MAX30205_bottom(&i2c1, MAX30205_I2C_SLAVE_ADDR_BOTTOM);
PMIC MAX14720 max14720(&i2c2,I2C_ADDR_PMIC);
DigitalOut led(LED1);
Serial Serial pc(USBTX, USBRX);
int main() { max14720.boostEn = MAX14720::BOOST_ENABLED; max14720.init();
led = 0;
Temperature Variables uint16_t rawTemp_top, rawTemp_bottom; float celsius_top, celsius_bottom;
Endless loop
while(1) { Read temperature MAX30205_top.readTemperature(&rawTemp_top); MAX30205_bottom.readTemperature(&rawTemp_bottom);
Convert to Celsius celsius_top = MAX30205_top.toCelsius(rawTemp_top); celsius_bottom = MAX30205_bottom.toCelsius(rawTemp_bottom);
Print Celsius Values pc.printf("Top Temperature: %.2f\370C\n\rBottom Temperature: %.2f\370C \n\n\r", celsius_top, celsius_bottom);
Wait 1 second wait(1); } }
And I use the libraries MAX30205 and MAX14720 from the following links https://os.mbed.com/teams/MaximIntegrated/code/MAX30205/ https://os.mbed.com/components/MAX14720/
The errors are the following
Error: No instance of constructor "MAX30205::MAX30205" matches the argument list in "main.cpp", Line: 15, Col: 24 Error: No instance of constructor "MAX30205::MAX30205" matches the argument list in "main.cpp", Line: 17, Col: 27 Error: Initial value of reference to non-const must be an lvalue in "main.cpp", Line: 42, Col: 39 Error: Initial value of reference to non-const must be an lvalue in "main.cpp", Line: 43, Col: 42
Thank you in advance for your time, with respect, Andrei Sas
Hello Andrei,
These errors appear because the functions/constructors you are using do not align with their declared parameters. Try removing the ampersands (&) in the following lines of code where the errors appear:
//Bottom Local Temperature Sensor
The code should be able to compile then. If you were confused on passing by pointer/reference, you can take a look at this article:
https://www.geeksforgeeks.org/passing-by-pointer-vs-passing-by-reference-in-c/
Hope this helps!
-Karen, team Mbed
the output of this program is 0.0 for top and 2.54 degree C for bottom temperature always. Can you help me regarding this?
posted by Jyothi Bhat 25 Oct 2018
