8 years, 1 month ago.
What is the size of the touch screen?
Must be really small because I couldn't find it even on the datasheet.
272x480 See : https://nxp.com/demoboard/om13092
The board uses an LCD panel with a built-in touch panel, which the LPC54608 device controls via I2C.
See the datasheet for the LCD panel under the documentation tab: https://www.nxp.com/docs/en/supporting-information/RK043FN02H-CT.pdf But it's dimensions in mm from that datasheet are 105.5 (W) x67.2(H) x4.35(D) Max
posted by 05 Apr 2018
