8 years ago.
How to compile and run program arm-musca board
Hello.
May you tell please how to compile and run program at arm musca board.
I tried 1) To compile and run samples with Keil studio (evalution license), I've got errors with both samples.
2) To compile sample with mbed https://os.mbed.com/docs/v5.8/tutorials/quick-start-offline.html. mbed compile --target arm_musca_A --toolchain GCC_ARM --flash
error: musca is not supported in mbed
3) To compile sample with online comipler https://os.mbed.com/compiler/#nav:/prog001/main.cpp; Error: Target "ARM_MUSCA" is not recognized.
SRAM 96KB QSPI 8MB
8 years ago.
Hi Alexey. The Mbed OS port for Musca is still in development. Once the porting is done, it will be enabled on the online compiler and you will also be able to build for it from the CLI. Currently the ETA is mid-May. Please watch this space for more updates. Thanks.
Just received long waited Musca board (Var C) . When will mbed support be enabled? Any time soon?
Thanks,
-Erkut
posted by Tran Zorb 23 Apr 2019
