8 years ago.
HardFault occurs when fopen() is called after EthernetInterface.connect(); (with mbed OS 5.4~5.8)
I'm trying to make a program with which to make LPC1768 a kind of a file server, which communicate with devices over Ethernet, and read/write text files in ther local drive of LPC1768.
I'm using :
  • LPC1768
  • mbed OS 5 (5.4.7 ~ 5.8.1)
  • Online ARM compiler
  • EthernetInterface (Class)
  • LocalFileSystem (Class)
LPC1768 is conneting to:
  • PC with USB
  • A router with LAN cable
and I have found that my mbed freezes when fopen() after EthernetInterface-instance.connect(). I extrated the part which has something wrong from my program. Following code can reproduce the error I had:
Import programeth-filesystem-sample
This program is published for a question I throw at the forum (https://os.mbed.com/questions/80658/HardFault-occurs-when-fopen-is-called-af/). I will thank you for answering my question. Abstract: LPC1768 freezes while processing this program, especially when fopen() is called after EthernetInterface.connect() P.S.' This problem is discussed here: https://github.com/ARMmbed/mbed-os/issues/6578
main.cpp
LocalFileSystem local("local");
void func();
EthernetInterface *net;
    func();
    net = new EthernetInterface();
    func();
    if(net->connect()) {
        printf("Error!@EthernetInterface::connect()\r\n");
    } else {
        printf("IP Address is %s\r\n", net->get_ip_address());
    func();
void func()
    static int i = 1;
    printf("-------test of fopen()#%d----\r\n", i);
    if(fopen("/local/test.txt", "r")==NULL)
        printf("File could not open\r\n");
    else
        printf("File was opened successfully.\r\n");
    i++;
When I connect the LPC1768 to a router with RJ45(LAN), and also to my PC with USB, and then I execute this program, I get following result on the console on my PC.
result
-------test of fopen()#1----
-------test of fopen()#2----
IP Address is 192.168.11.3
-------test of fopen()#3----                //printf() just before if-clause in func() does work
//here, LPC1768 hang up @fopen() just before printf() in if-clause in func()
Can you reproduce the error? or Can you tell me what did I do wrong? or Do some libraries have bugs? or Is there another new API to handle the local drive of LPC1768?
I will appreciate any comment!!! Thanks!!!
Quote:
Before, I made such programs with mbed OS 2(classic) and it perfectly worked. Following is the code which was slightly modified for mbed OS 2. In this case, I used:
  • LPC1768
  • mbed OS 2(classic)
  • mbed-rtos(lib; latest ver. @Mar22th,2018)
  • EthernetInterface (lib)
  • EhternetInterface (Class)
    Import programeth-filesystem-sample-mbed-classic
    LPC1768 DOESN'T freeze while processing this program, even when fopen() is called after EthernetInterface.connect() (with MBED OS 2) see also https://os.mbed.com/users/aktk/code/eth-filesystem-sample/
    and then I got following result
result
File was opened successfully.                            //DOESN'T freeze
Quote:
Postscript
I found that the program can catch the error end show it on console like below when I use mbed OS 5.8.0.
result
++ MbedOS Fault Handler ++
FaultType: HardFault
Context:
R0   : 00000001
R1   : 10002618
R2   : 00000000
R3   : 00003F00
R4   : 00000005
R5   : 1000263C
R6   : 00000000
R7   : 10000B8C
R8   : 00000000
R9   : FFFFFFFF
R10  : 00000000
R11  : 00000000
R12  : 000041BD
SP   : 10002618
LR   : 0000D0CB
PC   : 0000D0D0
xPSR : 01000000
PSP  : 100025F8
MSP  : 10007FD8
CPUID: 412FC230
HFSR : 80000000
MMFSR: 00000000
BFSR : 00000000
UFSR : 00000000
DFSR : 0000000A
AFSR : 00000000
SHCSR: 00000000
Thread Info:
Current:
State: 00000002 EntryFn: 0000CDCD Stack Size: 00001000 Mem: 100016A8 SP: 10002550
Next:
Wait Threads:
State: 00000083 EntryFn: 0000BFED Stack Size: 00000300 Mem: 10000610 SP: 100008A0
Delay Threads:
State: 00000043 EntryFn: 000115C1 Stack Size: 000004B0 Mem: 10002C08 SP: 10003020
Idle Thread:
State: 00000001 EntryFn: 0000B521 Stack Size: 00000200 Mem: 10000410 SP: 100005C8
-- MbedOS Fault Handler --
I cannot understand what the error means completely.
Quote:
Postscript #2
I found that it works when with mbed OS 5.3 as well as mbed OS 2!!!
I think that means the exception error is specific to mbed OS 5.4~5.8.1
posted by Akifumi Takahashi 27 Mar 2018
Tracking here: https://github.com/ARMmbed/mbed-os/issues/6578
posted by Jan Jongboom 09 Apr 2018
OK. Thanks for your helping!
posted by Akifumi Takahashi 10 Apr 2018
