8 years, 2 months ago.
Servo Motor
I am using a HS_785HB winch servo motor. It is a continuous rotation servo. The servo rotates i both the directions when no load is attached. But when I attach the rack and pinion load over it, it rotates only in one direction. What is the issue and how could I solve this? If possible can you please provide the code with it?
If it rotates without load but doesn't with one then it's almost certainly either an electrical or a mechanical issue rather than software.
What voltage are you supplying the servo?
What is the load and how does it compare to the servos maximum torque rating?
