8 years, 2 months ago.
Do you have any library for receiver and transmitter for arm mbed?
I'm using these two modules (https://sites.google.com/site/summerfuelrobots/arduino-sensor-tutorials/rf-wireless-transmitter-receiver-module-433mhz-for-arduino)
Hello Alan,
You can try to use the Manchester encoding library to drive the modules. There is available a Transmitter demo and a Receiver demo you can start with. I would recommend to begin at speed reduced to 600 bps and to send a short message. Once the transfer is working you can try to increase the speed and add more payload data step by step. Make sure you use the same transfer speed and message data for both modules.
Import the demos and modify the main.cpp as below :
Transmitter
#include "Manchester.h"
#include "CRC16.h"
DigitalOut led(LED1);
Manchester man(PA_8, PA_9, 600); // Tx pin, Rx pin (not connected), speed [bps]
ManchesterMsg msg(255); // Message container (max bytes)
CRC16 crc16; // CRC16 object
int main(void) {
msg.clear(); // Clear the message
//msg << "Hello World!" << 0xfa74c309; // Add some data to the message
msg << 0xfa; // Add some data to the message
msg << crc16.calc(msg.data, msg.len); // Append CRC16 to the message
man.transmit(msg); // Transmit the message
wait_ms(1000);
led = !led;
Receiver
#include "CRC16.h"
Manchester man(PA_8, PA_9, 600); // Tx pin (not connected), Rx pin, speed [bps]
ManchesterMsg msg(100); // Message container (max bytes)
//char str[80]; // Storage for the received array of char
//uint32_t val; // Storage for the value received
uint8_t val; // Storage for the value received
unsigned short recvCRC16; // CRC16 received in the message
unsigned short calcCRC16; // CRC16 calculated
int main(void) {
if(man.receive(msg)) { // Receive message
// Print data length and raw data bytes
printf("\r\n----------------------------------------\r\n");
printf("Message length = %d, Raw data :\r\n", msg.len);
for(size_t i = 0; i < msg.len; i++) {
if((i + 1) % 10 == 0)
printf(" %.2x\r\n", msg.data[i]);
else
printf(" %.2x", msg.data[i]);
printf("\r\n\r\n");
// Calculate CRC16. Exclude CRC bytes (last two bytes) from calculation.
calcCRC16 = crc16.calc(msg.data, msg.len - 2);
printf("Calculated CRC16 = %d\r\n", calcCRC16);
// Extract data and CRC16 from the message
//msg >> str >> val >> recvCRC16;
msg >> val >> recvCRC16;
printf("Received CRC16 = %d\r\n", recvCRC16);
printf("\r\n");
if( calcCRC16 == recvCRC16) {
printf("Received data :\r\n");
//printf(" str = %s\r\n", str);
printf(" val = 0x%x\r\n", val);
else
printf("CRC error\r\n");
else
printf("Error\r\n");
led = !led;
Warning: Incompatible voltage levels!
Because your NUCLEO board is runing at 3.3V and the RF modules at 5V, a voltage level converter has to be included into the connection line from the ATAD pin on the Receiver module to the PA_9 pin on the NUCLEO board in order to avoid damaging the NUCLEO board ! If you operate the Transmitter module at 5V I would recommend to use a voltage level converter also for the connection line from the PA_8 pin on the NUCLEO board to the DATA pin on the Transmitter module to assure reliable operation.
NOTE: Some pins on NUCLEO boards are 5V tolerant. Have a look at for example here. The PA_9 pin on the NUCLEO-F103RB board supposed to be such. In that case the voltage converter from 5V to 3.3V can be ommitted. However, use it at your own risk. I'll take no responsibility whatsoever for any damages to your MBED board!
Wiring
When supplied from 3.3V source:
| NUCLEO-F103RB | Transmitter module | |||
| GND | -> | GND | ||
| +3.3V | -> | VCC | ||
| PA_8 | -> | DATA |
When supplied from 5V source:
| GND | -> | GND | ||
| +5V | -> | VCC | ||
| PA_8 | -> Voltage level converter from 3.3V to 5V -> | DATA |
Supplied only from 5V source:
| Receiver module | NUCLEO-F103RB | |||
| GND | <- | GND | ||
| VCC | <- | +5V | ||
| ATAD | -> Voltage level converter from 5V to 3.3V -> | PA_9 |
With best regards,
Zoltan
