8 years, 2 months ago.
Using UbloxPPPCellularInterface with easy-connect
Trying to use the PPPcellular interface with easy connect and have enabled by uncommenting the entries: Note: we use UbloxAtCellularInterfaceExt here but the examples work with UbloxATCellularInterface, UbloxPPPCellularInterface or UbloxATCellularInterfaceN2xx (though noting that the N211 module supports only UDP and not TCP); simply uncomment/comment the correct options in the next few lines #include "UbloxATCellularInterfaceExt.h"
  1. include "UbloxPPPCellularInterface.h" #include "UbloxATCellularInterface.h" #include "UbloxATCellularInterfaceN2xx.h"
Parameters added to the call here simply to show how debug can be switched on For the N2xx interface, change xxx to MBED_CONF_UBLOX_CELL_N2XX_BAUD_RATE. UbloxATCellularInterfaceExt cellular(MDMTXD, MDMRXD, MBED_CONF_UBLOX_CELL_BAUD_RATE, false); UbloxPPPCellularInterface cellular; UbloxATCellularInterface cellular; UbloxATCellularInterfaceN2xx cellular;
However I am not able to compile (the orher interfaces compiles fine)
Compile [ 99.7%]: main.cpp [Error] easy-connect.h@45,1: 'UbloxPPPCellularInterface' does not name a type [Error] easy-connect.h@164,26: 'cellular' was not declared in this scope [ERROR] In file included from ./main.cpp:44:0: ./easy-connect/easy-connect.h:45:1: error: 'UbloxPPPCellularInterface' does not name a type UbloxPPPCellularInterface cellular; ^~~~~~~~~~~~~~~~~~~~~~~~ In file included from ./main.cpp:44:0: ./easy-connect/easy-connect.h: In function 'NetworkInterface* easy_connect(bool)': ./easy-connect/easy-connect.h:164:26: error: 'cellular' was not declared in this scope network_interface = &cellular; ^~~~~~~
Any suggestions ?
Development team for u-blox positioning and wireless products
It's difficult to say what's going wrong without knowing what your actually compiling.
What I've done below is to take the vanilla mbed-os-example-client, from scratch, and compile it with the fork of easy-connect that you are referring to above, just to show the steps to achieve a complete build. I've attached the files that I have edited, easy-connect.h and mbed_app.json, though note that I had to rename mbed_app.json to mbed_app_json.h as this forum interface doesn't seem to allow .json files to be uploaded.
Downloading the code:
>git clone https://github.com/ARMmbed/mbed-os-example-client
Cloning into 'mbed-os-example-client'...
remote: Counting objects: 1896, done.
remote: Compressing objects: 100% (21/21), done.
remote: Total 1896 (delta 10), reused 27 (delta 9), pack-reused 1866
Receiving objects: 100% (1896/1896), 8.03 MiB | 2.24 MiB/s, done.
Resolving deltas: 100% (981/981), done.
>cd mbed-os-example-client
mbed-os-example-client>del easy-connect.lib
mbed-os-example-client>mbed deploy
[mbed] Adding library "mbed-client" from "https://github.com/ARMmbed/mbed-client" at rev #ea04c5de7822
[mbed] Adding library "mbed-client\mbed-client-c" from "https://github.com/ARMmbed/mbed-client-c" at rev #ecfa619e42b2
[mbed] Adding library "mbed-client\mbed-client-classic" from "https://github.com/ARMmbed/mbed-client-classic" at rev #4e66929607c3
[mbed] Adding library "mbed-client\mbed-client-mbed-tls" from "https://github.com/ARMmbed/mbed-client-mbed-tls" at rev #7e1b6d815038
[mbed] Adding library "mbed-os" from "https://github.com/ARMmbed/mbed-os" at rev #2b4ff78ab0a5
[mbed] Adding library "pal" from "https://github.com/ARMmbed/pal" at rev #60ce64d5ec35
mbed-os-example-client>mbed add https://os.mbed.com/teams/ublox/code/ublox-ppp-cellular-interface/
[mbed] Adding library "ublox-ppp-cellular-interface" from "https://os.mbed.com/teams/ublox/code/ublox-ppp-cellular-interface" at latest revision in the current branch
[mbed] Updating reference "ublox-ppp-cellular-interface" -> "https://os.mbed.com/teams/ublox/code/ublox-ppp-cellular-interface/#4c533665168c"
warning: LF will be replaced by CRLF in ublox-ppp-cellular-interface.lib.
The file will have its original line endings in your working directory.
mbed-os-example-client>mbed add https://os.mbed.com/teams/ublox/code/ublox-cellular-base/
[mbed] Adding library "ublox-cellular-base" from "https://os.mbed.com/teams/ublox/code/ublox-cellular-base" at latest revision in the current branch
[mbed] Updating reference "ublox-cellular-base" -> "https://os.mbed.com/teams/ublox/code/ublox-cellular-base/#a15349fcab25"
warning: LF will be replaced by CRLF in ublox-cellular-base.lib.
mbed-os-example-client>mbed add https://os.mbed.com/teams/ublox/code/easy-connect/
[mbed] Adding library "easy-connect" from "https://os.mbed.com/teams/ublox/code/easy-connect" at latest revision in the current branch
[mbed] Updating library "easy-connect\atmel-rf-driver" to rev #3cc6010188c0
[mbed] Updating library "easy-connect\esp8266-driver" to rev #44fb447c72a3
[mbed] Updating library "easy-connect\esp8266-driver\ESP8266\ATParser" to rev #77734ee44a63
[mbed] Updating library "easy-connect\mcr20a-rf-driver" to rev #9aac10474702
[mbed] Updating library "easy-connect\stm-spirit1-rf-driver" to rev #cb5f1e808ee9
[mbed] Updating reference "easy-connect" -> "https://os.mbed.com/teams/ublox/code/easy-connect/#304d3ba87a01"
warning: LF will be replaced by CRLF in easy-connect.lib.
Edit easy-connect.h to #include "UbloxPPPCellularInterface.h" and define UbloxPPPCellularInterface cellular.
Edit the "config" section of mbed_app.json to define "network-interface" as having the value "CELLULAR_UBLOX".
Edit the "config" section of mbed_app.json to add the required values for "default-pin", "apn", "username" and "password".
Supply my own credentials in security.h.
Compiling the code:
mbed-os-example-client>mbed config root .
[mbed] . now set as default root in program "mbed-os-example-client"
mbed-os-example-client>mbed target UBLOX_C030_U201
[mbed] UBLOX_C030_U201 now set as default target in program "mbed-os-example-client"
mbed-os-example-client>mbed toolchain GCC_ARM
[mbed] GCC_ARM now set as default toolchain in program "mbed-os-example-client"
mbed-os-example-client>mbed compile
Building project mbed-os-example-client (UBLOX_C030_U201, GCC_ARM)
Scan: .
Scan: mbed
Scan: env
Scan: FEATURE_COMMON_PAL
Scan: FEATURE_LWIP
Scan: FEATURE_NANOSTACK
Compile [  0.1%]: at24mac.cpp
Compile [  0.3%]: MyBuffer.cpp
Compile [  0.4%]: ESP8266Interface.cpp
Compile [  0.6%]: NanostackRfPhyAtmel.cpp
Compile [  0.7%]: ATParser.cpp
Total Static RAM memory (data + bss): 70684 bytes
Total Flash memory (text + data): 317793 bytes
Image: .\BUILD\UBLOX_C030_U201\GCC_ARM\mbed-os-example-client.bin
Thanks for answering Rob
I did follow your example and compiled with success.
What i missed was an entry in `mbed_app.json':
```` "UBLOX_C027": { "lwip.ppp-enabled": true, "ppp-cell-iface.apn-lookup": true } ````
Now my project compiles.
posted by Jens-Ole Graulund 04 Jan 2018
