7 years, 12 months ago.
HTTPS post to custom TCP port number
I've been trying out the HTTPS post examples described here: https://os.mbed.com/teams/sandbox/code/http-example/
But I've been unable to get the example to work using my target server, which has a non-standard HTTPS port number (777, rather than 443).
I can open the socket to that custom port, using
TLSSocket* socket = new TLSSocket(network, "myserverhostname", 777, SSL_CA_PEM); if (socket->connect() != 0) { printf("TLS Connect failed %d\n", socket->error()); return; }
The TLS handshake and certificate validation goes just fine. But after I create any sort of request (get or post):
HttpsRequest* get_req = new HttpsRequest(socket, HTTP_GET, "https://myserverhostname:777/ingress/messages"); HttpResponse* get_res = get_req->send();
And then send that request, I keep receiving in reply a 400 invalid hostname error:
<!DOCTYPE HTML PUBLIC "-W3CDTD HTML 4.01EN""http://www.w3.org/TR/html4/strict.dtd"> <HTML><HEAD><TITLE>Bad Request</TITLE> <META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD> <BODY><h2>Bad Request - Invalid Hostname</h2> <hr><p>HTTP Error 400. The request hostname is invalid.</p> </BODY></HTML>
Is there a mistake I'm making that immediately stands out to anyone? Thanks!
7 years, 11 months ago.
I've pushed a fix to mbed-http. Can you verify if this solves your issue, if so I'll update the examples. You can do this by right clicking on mbed-http, then press 'Update...' (or if you're using Mbed CLI, go into mbed-http folder and run `hg pull`).
(Host header did not include port number for non-default ports, was no problem on my test server, but apparently other servers choke on it).
If you've a moment, I've set up a while(true) loop to loop through that POST line , followed by a delay of a few seconds, but right when I try to debug this code, the TLS handshake fails with
----- Setting up TLS connection ----- Connecting to myserverhostname:777 Starting the TLS handshake... CMSIS-RTOS error: Stack underflow (status: 0x1, task ID: 0x200101B0, task name: )
I'm running this code on a K64F, which should have plenty of resources for the code; it's rather odd because I can send a single HTTPS post without any problem, but as soon as I add the line that turns the code block into a loop, I start seeing the stack underflow again. Thanks again for all the help! The code I'm referring to looks like
TLSSocket* socket = new TLSSocket(network, ENDPOINT_HOST, ENDPOINT_PORT, SSL_CA_PEM);
socket->set_debug(true);
return 1;
// Main loop
//while (true) // This is the line that triggers the stack underflow error
// Read the sensor values; see https://os.mbed.com/components/FXOS8700Q/
acc.getAxis(acc_data);
// Assemble the message:
string body = DEVICE_NAME + "," + DEVICE_TEMPLATE + "\n" +
"X-acceleration:" + float_to_string(acc_data.x);
// POST request
// Create the new request
//HttpsRequest* post_req = new HttpsRequest(network, SSL_CA_PEM, HTTP_POST, TARGET_URL);
HttpsRequest* post_req = new HttpsRequest(socket, HTTP_POST, TARGET_URL);
// Turn on debugging - this hides TLS connection information
post_req->set_debug(true);
// Add headers: content type and authentication
post_req->set_header("Content-Type", "application/json");
// Note: the header value is "Basic " plus the base64 encoding of username:password
post_req->set_header("Authorization", BASIC_AUTH_HEADER);
// Send the body
HttpResponse* post_res = post_req->send(body.c_str(), strlen(body.c_str()));
// Check the response for an error
if (!post_res) {
printf("HttpRequest failed (error code %d)\n", post_req->get_error());
return 1;
// Print the response
dump_response(post_res);
// Free up the request object
delete post_req;
// Wait
wait(SECONDS_BETWEEN_MESSAGES);
A simple trick would be to increase stack size for the main thread (or spin up a new thread with larger stack and run from there): https://os.mbed.com/docs/v5.6/reference/configuration.html
posted by 15 Dec 2017
In http_request_builder.h, can you uncomment line 110, and dump the full request here?
posted by Jan Jongboom 14 Dec 2017
