10 years, 11 months ago.
7" RA8875 and STM32-nucleo
Has anyone tried to run this library with a 7 "display? On stm32 Nucleo not work (( may have some nuances?
Hi Vitaliy, I've migrated from the 4.3 to the 5" display, but both are the 480 x 272 pixels formats. As I created the SW, I did try to keep in mind the larger display with the 800 x 480 pixel layout, but I had no way to test.
If your work is for the 7" w/Cap Touch display (for example), I would try to help you figure out any needed changes to the driver.
For the capacitive touch screen, on the other hand, you might be more on your own. I mention on the Components - RA8875 page that I don't have any support for that simply due to the fact that for my project needs I could not give up the extra pins needed for the I2C interface to support the cap-sense controller (so I didn't buy one). I tried searching the mbed site but couldn't find any work of others that might fill that gap.
2017 Update: This is an old post, but in the summer of 2016 I picked up a 7" display, 800x480, and with the capacitive touch panel. I've integrated the touch driver into the base code, so that it [more or less] transparently supports either the resistive or the capacitive. Of course, only the CAP sense version handles multi-touch.
Thanks for the answer, I'll continue to investigate. I display ER-TFTM070-5 http://www.buydisplay.com/default/7-inch-lcd-module-capacitive-touch-screen-panel-i2c-spi-serial, configuration 4-wire SPI + Resistive Touch Screen.
posted by Vitaliy Shulyakov 15 May 2015
Please HELP!!!, as I can not run on Nucleo-f411ge display ER-TFTM070-5http://www.buydisplay.com/default/7-inch-lcd-module-capacitive-touch-screen-panel-i2c-spi-serial
RA8875 lcd(PA_7, PA_6, PA_5, PB_6, NC, "tft"); MOSI, MISO, SCK, /ChipSelect, /reset, name
posted by Vitaliy Shulyakov 18 Sep 2015
10 years, 10 months ago.
Removed answer wrong page, I'm sorry.
