8 years, 4 months ago.
How can I change SPI clock frequency?
I am using NUCLEO-F767ZI as SPI master. The default SPI clock of this model is set to 1 MHz. I want to use 1 kHz clock for the SPI, but spi.frequency(1000) function is not work. How can I change SPI clock?
best regards,
The minimum SPI frequency is the SPI clock divided by 256.
For this device, the SPI clock is configured to 54 MHz for SPI2/SPI3 and 108 MHz for SPI1/SPI4/SPI5/SPI6.
So, the minimum frequency you can achieve is around 211 kHz (54 MHz/256) or 422 kHz (108 MHz/256).
This can be modified, but you need to use mbed-dev and change the clock prescalers in the system_clock.c file.
Added this WIKI :
https://os.mbed.com/teams/ST/wiki/SPI-output-clock-frequency
posted by 17 Nov 20178 years, 4 months ago.
That is quite a low a frequency. I'm not sure this board would support such a low frequency. Without digging into their HAL, I would suggest trying to decrement from 1 MHz until you reach the limit.
