8 years, 5 months ago.
View and modify the mbed underlying source file
Mbed environment development STM32, I want to know how to modify the underlying source file in mbed environment?
Mbed 2 or mbed 5? I'm going to assume you mean the online compiler since offline you probably already have the source.
For the old mbed 2 libraries in the online compiler import the mbed-dev library in place of the mbed one and you'll get the full source.
For mbed 5 (mbed-os) the source is here: https://github.com/ARMmbed/mbed-os. If you want to be able to modify it in the online system create a github account, create a fork of the library into your account, copy the URL of that version and then in the online compiler select import library from URL. You will then get the full source visible and modifiable in the online compiler.
Are you using the online compiler or mbed-cli? Are you asking how to modify files in one of the libraries (*.lib) files?
posted by Michael Bartling 13 Nov 2017I say, for example, This Board, NCULEO-STM32F767ZIT6,in this board ,The GPIOs,PA9,PA10, Cannt be used as a serial port. But we all konw ,PA9 PA10 they are USART1's IO . so what should I do ?
posted by pusheng wu 14 Nov 2017Which country do you belong to? Do you have other contact information, such as QQ WeChat?
