10 years, 11 months ago.
Linker Error Using GCC for ARM -- Possibly missing object file or not included in the Makefile?
I am trying to use GCC for ARM embedded version 4.9.2 on Windows 7 Pro. My target is a FRDM-KL25Z. I have a very simple blinky program that tests 3 LEDs I have on a custom daughterboard mounted to the FRDM board. This program compiles and works fine when built with the online compiler, but when compiling the exported code using GCC for ARM I get this linker error that it can't resolve one of the system functions:
c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-eabi/4.9.2/../../../../arm-eabi/lib/thumb/cortex_m0plus/crt0.o: In function `_start':
/q/gnu/auto/ --- <long path deleted> --- /sys/arm/crt0.S:273: undefined reference to `initialise_monitor_handles'
collect2.exe: error: ld returned 1 exit status
make: *** [Test_LEDs.elf] Error 1
Am I missing a system object file or failing to compile it because it's not in the Makefile? Or maybe my GCC version is too new for MBED? Here is my code:
Test_LEDs.cpp
//  Tests functionality of the 3 LEDs on the Pump Switch board
//  10/6/2014  TBC
DigitalOut LowBatt(PTD2, 1);
DigitalOut PwrFail(PTE4, 1);
DigitalOut OK(PTE5, 1);
int main( )
    float t = 0.1;
    while ( 1 )
        LowBatt = 0;
        wait( t );
        LowBatt = 1;
        PwrFail = 0;
        wait( t );
        PwrFail = 1;
        OK = 0;
        wait( t );
        OK = 1;
    return 0;
Thanks for your help.
