-deleted-
8 years, 5 months ago.
Struggling with basic code for a servo motor
So im currently doing a project and have just kinda been thrown into using an the NUCLEO-F401RE board for a buggy. This buggy requires the use of a servo motor and at the moment im just trying to have full access of all angles using a pwm signal, I have attached this very basic code below and can only get the motor to change from 0 degrees to 180 degrees changing the value of ' mypwm.pulsewidth_ms();' from 1 to 2. Unfortunately it has been quite some time since I have used c coding and was never that great at it in the first place and am completely inexperienced with what I am doing at the moment. So I am just trying to have full access of all the angles and have tried using decimal places like 1.5 but this just would round down to 1 hence an angle of 0 degrees. I have tried troubleshooting this code with the use of floats and various other websites I have found online with no luck, as a novice I am struggling and if anyone could help me I would be extremely grateful. Thank you to anyone who bothers helping in advance although im kinda doubting anyone will. 
code:
  1. include "mbed.h"
PwmOut mypwm(PA_7);
mypwm.period_ms(20); mypwm.pulsewidth_ms(1);
Jason,
Which servo are you trying to control?
Some servos only have binary angle control, meaning you can only set them to 0 or 180 degrees. Other servos don't even have a full 180 degree rotation. Either way, a spec sheet or part # of the servo you are trying to use could clear things up.
The code you have is good to go for a general case. You should be able to change the pulse width from a range of integer values starting at 1ms, to whatever your period is (in this case, 20ms). The duty cycle then corresponds to a specific angle and will set your servo to that angle.
Not sure if you're aware of this page: https://os.mbed.com/components/cat/actuators/ Might have some examples that work out for you. Any of the NXP examples should port easily to the Nucleo.
Try the following code, you can use the member function period_us instead of period_ms so you can resolve pulsewidths less than 1ms.
//Program to 'sweep' test a 'standard RC type servo
//Define some parameters using compiler directive '#define'
//Check Servo DATA if 0.75ms to 2.25ms then use min=750 and max=2250
//NB be values in microseconds (Following are generic values)
#define MID         1500
#define MIN         1000
#define MAX         2000
#define STEP          50
//Time delay between steps in milliseconds
#define TIME         100
DigitalOut myLed(LED1);
DigitalIn  myButton(USER_BUTTON);
PwmOut myServo(PA_7);
    myServo.period_ms(20);
    myServo.pulsewidth_us(MID); //NB in microseconds
    while(true) {
        for (int i=MIN;i<=MAX;i+=STEP){
            myServo.pulsewidth_us(i);
            wait_ms(TIME);
        for (int i=MAX;i>=MIN;i-=STEP){
            wait_ms(TIME);
Hope this helps,/explains
