8 years, 3 months ago.
EthernetInterface is still not supported
When compiling, it just show Error: #error directive: The Ethernet Interface library is not supported on this target in "F7_Ethernet/EthernetInterface.h", Line: 24, Col: 3 It seems the library have not updated yet to support this board, any idea?
STM32 Nucleo-144 development board with STM32F767ZIT6 MCU, supports Arduino, ST Zio and morpho connectivity
I just tested the simple example named "mbed-os-tcp-server-example;" on NUCLEO_F767ZI and this works fine here. (note: I'm using mbed-os v5.6.2).
posted by Laurent Meunier 18 Oct 2017
Can you give more details about your issue background: Mbed version? Compiler? What you want to do with Ethernet?(code example can put in main message use this editing tips <<code >> your code <</code>> )
You need to use mbed-os to be able to use EthernetInterface.
If you dont want to use mbed-os also there is this project https://os.mbed.com/users/DieterGraef/code/Nucleo_F746ZG_Ethernet/ for classic mbed.
Daniel
thanks for your reply, in fact I have try both mbed-os and the linked library you give above. But when I try mbed-os, my program without ethernet function not work properly. I cant find a document stating out what's difference with mbed. So I cant solve what's wrong going on. And Nucleo_F746ZG, it's not compatible with 767zi,Error: #error directive: The Ethernet Interface library is not supported on this target in "Nucleo_F746ZG_Ethernet/F7_Ethernet/EthernetInterface.h", Line: 24, Col: 3. I am using the online mbed complier, 5.6.2 mbed. I expected to run the program with mbed 5.6.2 and the EthernetInterface library found on mbed online complier, it seems the EthernetInterface have not updated to support this.And I am just trying the ethernet template on the mbed handbook. I'm a newbird.
posted by Chen Pak Lam 17 Oct 2017
Can you share please your code? May be you using outdated example
Also for me worked fine library for NucleoF746, just then compile I choose NucleoF746 and flash binary to my NucleoF767. Not sure if other functions will work but mainly all F7 series are compatible
Check this example which is up to date: https://github.com/ARMmbed/mbed-os-example-sockets
posted by Daniel Klioc 17 Oct 2017
