8 years, 6 months ago.
go_position completion
Hi
I'm using a NUCLEO-F446RE with your StepperMotorUni library. When I use the go_position function the stepper will go to the required position but once there it will activate the A line instead of keeping the lines active for the last position. Do you have any idea as to why this is happening and the lines aren't remaining as on the last step?
Thanks
Richard
