8 years, 8 months ago.
Thread called only once when thread is created
Hi , I tried a thread program to glow an LED in the Disco-L476VG board.But the thread i s called only once when created.
I have toggled another LED in main thread which keeps going but new thread is called only once.
My prog
#include "rtos.h"
Thread thread;
DigitalOut led_red(LED2);
DigitalOut led_green(LED1);
void led2_thread(DigitalOut *led) {
while (true) {
*led = !*led;
Thread::wait(1);
thread.start(led2_thread,&led_red);
while (true) {
led_green = !led_green;
Thread::wait(500);
What would be the prob,I am using mbed-os version 5.3.3 .
Is thread is not stable with STM32 ?
Thanks, E.k
You cannot read the value of the LED through *led, as it returns the object (and does not use the operator overloading which is normally used) and thus always evaluates to the same value. E.g. *led on my NUCLEO-F411RE returns 32 all the time, thus the same value is written to the LED.
Instead, do this:
*led = !led->read();
Hello Karthick,
Instead of calling Thread::wait(float) try to call wait(float) (or wait_ms(int)) as below.
NOTE: I assume that the 500s delay in main's while loop was a typo not an intention.
#include "rtos.h"
Thread thread;
void led2_thread(DigitalOut* led) {
while (true) {
*led = !*led;
wait(1.0);
int main(void) {
thread.start(callback(led2_thread, &led_red));
while (true) {
wait(0.5);
Sorry, it seems that the typo wasn't in the main's while loop but in the led2_thread function. Nevertheless, both solutions (with wait(float) above as well as with Thread::wait(int) below) should work fine.
#include "rtos.h"
Thread thread;
while (true) {
*led = !*led;
Thread::wait(1000);
int main(void) {
while (true) {
Thread::wait(500);
I believe that Thread::wait(500) is 500 milliseconds. The pre-OS wait(500) is both a blocking wait, and is measured in seconds. (It takes a float, so wait(0.5) would be 500 msec.
*led = !*led;
works also fine.
Thread::wait(500);
waits for 500 ms, that is ok. But in led2_thread, you wait only for 1 ms. So your eyes must be damned fast to see the LED blinking :-)
