8 years, 7 months ago.
undefinde identifier
Dear forum users when I run the simpel display code ( to run the smily exampel) I get teh folowing error :
Error: Identifier "p13" is undefined in "microbit/microbit-dal/inc/drivers/MicroBitMatrixMaps.h", Line: 155, Col: 6 Error: Identifier "p4" is undefined in "microbit/microbit-dal/inc/drivers/MicroBitMatrixMaps.h", Line: 156, Col: 6
Doe's some one know where the problem lies?
With best regards Ben
Hi Ben,
If you are using the Online Compiler, please check to make sure you are compiling for the correct target board (the BBC micro:bit). You can change your target board by clicking on the board shown on the top right hand corner of the Online Compiler page.
When you click on the current Target Platform image a pop-up called "Select a Platform" should be displayed. Select the micro:bit image then click the green "Select Platform" checkmark.
If you don't have the micro:bit as a registered platform, you can add it to your online compiler by selecting the "Add Platform" button.
Please let me know if this solves your errors and if you need any further assistance!
- Jenny
Hi Jenny,
I also have a same problem in my mbed CLI environment.
The pins are defined with an upper-case letter in the mbed library PinNames.h of TARGET_NRF51_MICROBIT.
P13 = P0_23
But in the microbit library MicroBitMatrixMaps.h, the pin is called with a lower-case letter.
#define MICROBIT_DISPLAY_ROW1 p13
So the error occurs when I include MicroBit.h.
#include "MicroBit.h"
Could you please tell me any ideas to solve if you have?
Best regards,
-Akanuma Hiroaki
posted by 30 Oct 2017
Try P13 not p13
posted by Andy A 10 Jul 2017
