8 years, 8 months ago.
function atof() lost precision (wrong conversion)
Hello, i'm trying to work with number and string, when i read the string 50.6 the program read the string well but, when a convert it with atof() and pc.printf("%f", result) it prints 50.999998
Here's just a little part of my code:
char txt[100]; char *p; float test; FILE *m_fFilePath = fopen("/sd/valeurs.txt", "r"); if(m_fFilePath != NULL) { pc.printf("read open\n\r"); fgets(txt, 100, m_fFilePath); p = strtok (txt,",") ; setpoint.f = atof(p); p = strtok (NULL,",") ; test = atof(p);
pc.printf("%s\n\r",p); PRINT 50.6
pc.printf("%f\n\r",test); PRINT 50.999998 [...]
How it is possible to lose precision with atof????
Your code with <<code>> tags so that it's easier to read...
char txt[100];
char *p;
float test;
   test = atof(p);
  pc.printf("%s\n\r",p); // PRINT 50.6
  pc.printf("%f\n\r",test); // PRINT 50.999998
posted by Andy A 07 Jul 2017
It would help to know exactly what the input string looks like. And printf the txt string after you read it, to be sure you have what you think you have.
posted by Graham S. 08 Jul 2017
The atof() returns double type. So, your code implicitly converted from double to float and you lost precision.
http://www.cplusplus.com/reference/cstdlib/atof/
I wrote simple code below, and worked fine.
    char buf[20];
    sprintf(buf, "50.6");
    printf("value = %s\n", buf);
    double f = atof(buf);
    printf("value = %f\n", f);
        wait(0.2);
A float is no so inaccurate that 50.6 would becomes 50.999998. 50.6 becoming 50.599998 I would accept but not an error of almost 1%, floats are more accurate than that. There must be something else going on as well.
