8 years, 9 months ago. This question has been closed. Reason: Duplicate question
PG_0 INTERRUPT IN
Hi all, I'm having same troubles with Interrupts with pin PG_0 on my NUCLEO-F767ZI board. I have all configured properly and other pins that I used for InterruptIn are all working as they should.
Snippet from my code:
<code> InterruptIn in0(PG_0);
in0.mode(PullUp); int in0_ = 0;
void in0_change() { in0_ = in0.read(); }
int main(){ in0.rise(&in0_change); in0.fall(&in0_change);
while(1){ ...code } }
</code>
But if I do in0.read() it works just fine.
Why is then pin PG_0 special? Where can I find a list of pins that can be used as Interrupt input?
Thanks for the help.
