8 years, 9 months ago.
IDW01M1_Cloud_IBM "Operator new[] out of memory" ERROR on IDW01M1+STM32L073
the IDW01M1_Cloud_IBM example project is compiling without errors, but I'm getting the "Operator new[] out of memory" error in the serial terminal. I think it's related to dynamic memory allocation (malloc), but the Nucleo-STM32L073 is mentioned as compatible with this example project. Can someone help me? There is some known RAM requirements using these libraries? Thanks in advance.
Stefano
Ciao Stefano,
in fact footprint and RAM size used by the full application are too big for Nucleo-L073RZ.
If NFC is not strictly needed and you want to stick with L073RZ, I would suggest to remove the part related to X-NUCLEO-NFC01A1 expansion board. This can be achieved by commenting out X_NUCLEO_NFC01A1_PRESENT macro in main.cpp and removing both X_NUCLEO_NFC01A1 and NDefLib libraries from the program.
I just tried with online compiler and the generated binary works on my side using Nucleo-L073RZ.
Hope this helps.
Nicola
