8 years, 8 months ago.
How to make printf work with the STM32F429I-DISCO Board
I have been able to get printf to work on the STM32F429!-DISCO version of the board using the STM32-Cube software to build a runtime library that I use with EmBitz v1.11 (which uses GCC). Here's what I did:
Maybe you can make it work in mbed? Here's what I did:
In file STM32Cube_FW_F4_V1.16.0\Utilities\Log\lcd_log.c:
  • Find the function whose function header is a macro named: LCD_LOG_PUTCHAR
  • Replace the macro name (the entire line) with: int Put1Char(int ch)
  • Add the following function to the same file:
int _write(int file, char *ptr, int len)
   int i;
   for (i = 0; i < len; i++)  Put1Char(*ptr++) ;
   return len ;
That's all it took!
Dan Lewis dlewis@scu.edu
The STM32F429 Discovery kit (STM32F429I-DISC1) allows users to easily develop applications with the STM32F429 high-performance MCUs with ARM®Cortex®-M4 core.
7 years, 3 months ago.
Possible ff used external USB/TTL converter like FTDI and connect to UART.
8 years, 5 months ago.
STM32F429I-DISCO Board does NOT support printf, STM32F429I-DISC1 Board supports printf.
