8 years, 10 months ago.
STM32f411RE-Nucleo. Trying to get DMA working with ADC. DMA has an initialization error.
Main.h ADC with DMA transfer to memory
  * File Name          : main.c
  * Description        : Main program body
  * COPYRIGHT(c) 2017 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Includes ------------------------------------------------------------------*/
//#include "stm32f4xx_hal.h"
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
ADC_HandleTypeDef   hadc1;
DMA_HandleTypeDef   hdma_adc1;
GPIO_InitTypeDef    GPIO_InitStruct;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
void Error_Handler(void);
static void MX_GPIO_Init(void);
static void MX_DMA_Init(void);
static void MX_ADC1_Init(void);
/* USER CODE BEGIN PFP */
uint32_t ADC1ConvertedValues[1024];
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
int main(void)
    pc.printf("Main is Starting\n");
    /* USER CODE BEGIN 1 */
    /* USER CODE END 1 */
    /* MCU Configuration----------------------------------------------------------*/
    /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
    HAL_Init();
    /* Configure the system clock */
    SystemClock_Config();
    /* Initialize all configured peripherals */
    MX_GPIO_Init();
    MX_DMA_Init();
    MX_ADC1_Init();
    pc.printf("DMA and ADC Init'd\n");
    /* USER CODE BEGIN 2 */
    // -- Enables ADC and starts conversion of the regular channels.
    if( HAL_ADC_Start(&hadc1) != HAL_OK) {
        pc.printf("ADC Start Error\n");
        return 0;
    pc.printf("ADC Start Ok\n");
    // -- Enables ADC DMA request
    if (HAL_ADC_Start_DMA(&hadc1, (uint32_t*)ADC1ConvertedValues, 2048) != HAL_OK) {
        pc.printf("DMA Start Error\n");
        return 0;
    pc.printf("DMA Start Ok\n");
    pc.printf("Main read to loop\n");
    /* USER CODE END 2 */
    /* Infinite loop */
    /* USER CODE BEGIN WHILE */
    while (1) {
        /* USER CODE END WHILE */
        for (int i=0; i<2049; i++) {
            pc.printf("Analog Buffer Values %d\n",ADC1ConvertedValues[i]);
        /* USER CODE BEGIN 3 */
    /* USER CODE END 3 */
/** System Clock Configuration
    RCC_OscInitTypeDef RCC_OscInitStruct;
    RCC_ClkInitTypeDef RCC_ClkInitStruct;
    __HAL_RCC_PWR_CLK_ENABLE();
    __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
    RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
    RCC_OscInitStruct.HSIState = RCC_HSI_ON;
    RCC_OscInitStruct.HSICalibrationValue = 16;
    RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
    RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
    RCC_OscInitStruct.PLL.PLLM = 16;
    RCC_OscInitStruct.PLL.PLLN = 336;
    RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV4;
    RCC_OscInitStruct.PLL.PLLQ = 4;
    if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) {
        Error_Handler();
    RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                                  |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
    RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
    RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
    RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
    RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
    if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK) {
        Error_Handler();
    HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
    HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
    /* SysTick_IRQn interrupt configuration */
    HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
    pc.printf("Sys Init Done\n");
/* ADC1 init function */
    pc.printf("ADC Init\n");
    ADC_ChannelConfTypeDef sConfig;
    ADC_InjectionConfTypeDef sConfigInjected;
    /**Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
    hadc1.Instance = ADC1;
    hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4;
    hadc1.Init.Resolution = ADC_RESOLUTION_12B;
    hadc1.Init.ScanConvMode = ENABLE;
    hadc1.Init.ContinuousConvMode = ENABLE;
    hadc1.Init.DiscontinuousConvMode = DISABLE;
    hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
    hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
    hadc1.Init.NbrOfConversion = 4;
    hadc1.Init.DMAContinuousRequests = ENABLE;
    hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
    if (HAL_ADC_Init(&hadc1) != HAL_OK) {
        Error_Handler();
    pc.printf("ADC Config'd\n");
    /**Configure for the selected ADC regular channel its corresponding rank in the sequencer and its sample time.
    sConfig.Channel = ADC_CHANNEL_0;
    sConfig.Rank = 1;
    sConfig.SamplingTime = ADC_SAMPLETIME_3CYCLES;
    if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK) {
        pc.printf("ADC Error ch0\n");
        Error_Handler();
    pc.printf("ADC Config ch0\n");
    sConfig.Channel = ADC_CHANNEL_1;
    sConfig.Rank = 2;
        pc.printf("ADC Error ch1\n");
        Error_Handler();
    pc.printf("ADC Config ch1\n");
    sConfig.Channel = ADC_CHANNEL_2;
    sConfig.Rank = 3;
        pc.printf("ADC Error ch2\n");
        Error_Handler();
    pc.printf("ADC Config ch2\n");
    sConfig.Channel = ADC_CHANNEL_3;
    sConfig.Rank = 4;
        pc.printf("ADC Error ch3\n");
        Error_Handler();
    pc.printf("ADC Config ch3\n");
    /**Configures for the selected ADC injected channel its corresponding rank in the sequencer and its sample time
    sConfigInjected.InjectedChannel = ADC_CHANNEL_0;
    sConfigInjected.InjectedRank = 1;
    sConfigInjected.InjectedNbrOfConversion = 1;
    sConfigInjected.InjectedSamplingTime = ADC_SAMPLETIME_3CYCLES;
    sConfigInjected.ExternalTrigInjecConvEdge = ADC_EXTERNALTRIGINJECCONVEDGE_NONE;
    sConfigInjected.AutoInjectedConv = DISABLE;
    sConfigInjected.InjectedDiscontinuousConvMode = DISABLE;
    sConfigInjected.InjectedOffset = 0;
    if (HAL_ADCEx_InjectedConfigChannel(&hadc1, &sConfigInjected) != HAL_OK) {
        pc.printf("ADC Error inject\n");
        Error_Handler();
    pc.printf("ADC Config injected\n");
  * Enable DMA controller clock
    pc.printf("DMA Init\n");
    /* DMA controller clock enable */
    __HAL_RCC_DMA2_CLK_ENABLE();
    /* DMA interrupt init */
    /* DMA2_Stream0_IRQn interrupt configuration */
    HAL_NVIC_SetPriority(DMA2_Stream0_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(DMA2_Stream0_IRQn);
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
//GPIO_InitTypeDef GPIO_InitStruct;
    ///* GPIO Ports Clock Enable */
    __HAL_RCC_GPIOC_CLK_ENABLE();
    __HAL_RCC_GPIOH_CLK_ENABLE();
    __HAL_RCC_GPIOA_CLK_ENABLE();
    __HAL_RCC_GPIOB_CLK_ENABLE();
    /* Configure GPIO pins ******************************************************/
    //GPIO_InitStruct.Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3;// PC0, PC1, PC2, PC3
    //GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;//The pins are configured in analog mode
    //GPIO_InitStruct.Pull = GPIO_NOPULL; ;//We don't need any pull up or pull down
    //GPIO_Init(GPIOC, &GPIO_InitStruct);//Initialize GPIOC pins with the configuration
    //GPIO_InitStruct.GPIO_Pin = GPIO_Pin_1;//PA1
    //HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);//Initialize GPIOA pins with the configuration
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @param  None
  * @retval None
    /* USER CODE BEGIN Error_Handler */
    /* User can add his own implementation to report the HAL error return state */
    pc.printf("ADC Error\n");
    /* USER CODE END Error_Handler */
#ifdef USE_FULL_ASSERT
   * @brief Reports the name of the source file and the source line number
   * where the assert_param error has occurred.
   * @param file: pointer to the source file name
   * @param line: assert_param error line source number
   * @retval None
void assert_failed(uint8_t* file, uint32_t line)
    /* USER CODE BEGIN 6 */
    /* User can add his own implementation to report the file name and line number,
      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
    /* USER CODE END 6 */
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
I don't even know if this is possible. The code comes from QubeMX (saved as MDK v5) and compiles with mbed. But I suspect the DMA is not playing nice with MBED, there's an initialization error. I am trying to make a touch screen much more responsive. I need 20ms updates for the touch screen to work correctly. I must have an interrupt to sense touch, then delay. Then read an average of touch. Then no touch present.
This is where I get a DMA start error.
        return 0;
Hi. Believe that when you use CubeMX and save as MDK v5 then you have exported the generated code to be compiled with the Keil Compiler v5 only.
http://www2.keil.com/mdk5/
Should compile fine with that tool.
I was trying to get control of the hardware layer of MBED. I kind of thought maybe this wasn't the best way. I will probably try the MBED SDK and see how far I can get with that. Thanks for your response.
posted by Darren Ulrich 18 May 2017
