8 years, 10 months ago.
How to convert this arduino code to kl25z mbed?
Good day programmers! I would like to ask for help on how to convert this arduino code to mbed. This code is for a Dissolved Oxygen sensor. Reference: https://www.atlas-scientific.com/_files/code/Arduino-Uno-DO-sample-code.pdf
- include <SoftwareSerial.h> we have to include the SoftwareSerial library, or else we can't use it
- define rx 2 define what pin rx is going to be
- define tx 3 define what pin tx is going to be
SoftwareSerial myserial(rx, tx); define how the soft serial port is going to work
String inputstring = ""; a string to hold incoming data from the PC String sensorstring = ""; a string to hold the data from the Atlas Scientific product boolean input_string_complete = false; have we received all the data from the PC boolean sensor_string_complete = false; have we received all the data from the Atlas Scientific product float DO; used to hold a floating point number that is the DO
void setup() { set up the hardware Serial.begin(9600); set baud rate for the hardware serial port_0 to 9600 myserial.begin(9600); set baud rate for the software serial port to 9600 inputstring.reserve(10); set aside some bytes for receiving data from the PC sensorstring.reserve(30); set aside some bytes for receiving data from Atlas Scientific product }
void serialEvent() { if the hardware serial port_0 receives a char inputstring = Serial.readStringUntil(13); read the string until we see a <CR> input_string_complete = true; set the flag used to tell if we have received a completed string from the PC }
void loop() { here we go...
if (input_string_complete){ if a string from the PC has been received in its entirety myserial.print(inputstring); send that string to the Atlas Scientific product myserial.print('\r'); add a <CR> to the end of the string inputstring = ""; clear the string input_string_complete = false; reset the flag used to tell if we have received a completed string from the PC }
if (myserial.available() > 0) { if we see that the Atlas Scientific product has sent a character char inchar = (char)myserial.read(); get the char we just received sensorstring += inchar; add the char to the var called sensorstring if (inchar == '\r') { if the incoming character is a <CR> sensor_string_complete = true; set the flag } }
if (sensor_string_complete== true) { if a string from the Atlas Scientific product has been received in its entirety Serial.println(sensorstring); send that string to the PC's serial monitor if (isdigit(sensorstring[0])) { if the first character in the string is a digit DO = sensorstring.toFloat(); convert the string to a floating point number so it can be evaluated by the Arduino if (DO >= 6.0) { if the DO is greater than or equal to 6.0 Serial.println("high"); print "high" this is demonstrating that the Arduino is evaluating the DO as a number and not as a string } if (DO <= 5.99) { if the DO is less than or equal to 5.99 Serial.println("low"); print "low" this is demonstrating that the Arduino is evaluating the DO as a number and not as a string } } sensorstring = ""; clear the string sensor_string_complete = false; reset the flag used to tell if we have received a completed string from the Atlas Scientific product } }
HI,
the code could look like these:
#include <ctype.h>
Serial serial(USBTX, USBRX); // Define the serial port to the PC
Serial myserial(PTE22, PTE23); // Define how the serial port to the Disolved Oxygen Sensor
char inputString[10] = ""; // A char array to hold incoming data from the PC. set asaide some bytes.
char sensorString[30] = ""; // A char array to hold the data from the Atlas Scientific product. set asaide some bytes.
int input_string_complete = 0; // have we received all the data from the PC
int sensor_string_complete = 0; // have we received all the data from the Atlas Scientific product
float DO = 0.0; // used to hold a floating point number that is the DO
serial.baud(9600);
myserial.baud(9600);
while (true) { // here we go
if (serial.readable()) { // if the hardware serial port receiver a char
char inchar = serial.getc() // read the char
strcat(inputString, inchar); // concatenate the char array
if (inchar == 13) { // if the char is equal to 13 <CR>
input_string_complete = 1.0; // set the flag used to tell if we hace received a completed string from the PC
if (input_string_complete){ // if a string from the PC has been received in its entirety
myserial.printf("%s\r\n", inputString); // send that string to the Atlas Scientific Product add CR to the end of the string
inputString[0] = "\0"; // clear the string
input_string_complete = 0; // reset the flag used to tell if we have received a completed string from the PC
if (myserial.readable()) { // if we see that the Atlas Scientific Product has sent a character
char inchar = myserial.getc() // get the char we just received
strcat(sensorString, inchar); // add the char to the var called sensorString
if (inchar == '\r') { // if the incoming character is a <CR>
sensor_string_complete = 1; // set the flag
if (sensor_string_complete) { // if a string from the Atlas Scientific product has been received in its entirety
serial.printf("%s",sensorString); // send that string to the PC's Serial Monitor
if (isdigit(sensorString[0])) { // if the first character in the string is a digit
DO = atof(sensorString); // convert the string to a floating point number so it can be evaluated by the mbed
if (DO >= 6.0) { // if the DO is greater than or equal to 6.0
serial.printf("high"); // print "high" this is demonstrating that the mbed is evaluating the DO as a number
} else { // and not as a string. Else (if the DO is less than 6.00) print "low" this is demonstrating
serial.printf("low"); // than the mbed is evaluating the DO as a number and not as a string
sensorString[0] = "\0"; // clear the string
sensor_string_complete = 0; // reset the flag used to tell if we have received a completed string from the
} // Atlas Scientific product
wait_ms(100); // wait a small period of time
myled = !myled; // toggle a led
IMPORTANT NOTES: I don't know if the "ctype.h" is available on mbed. Not sure if it will work I don't have a KL25Z to test. I only have nucleo boards availables.
I would prefer to change several things on that code but you got an idea.
Best regards.
Please edit the post to use code tags e.g.
So that the formatting is preserved and we can tell which bits are comments.
posted by Andy A 04 May 2017
