8 years, 10 months ago.
SDFileSystem Compiler Errors
I thought I would share this:
I was getting the following errors when compiling
This is not a problem with the SDFileSystem library. It took me a day to figure it out, but it turned out my copy of mbed-os had somehow gotten corrupted. I had even updated the revision but that did not clear the errors. It was only when I deleted it out of the project and then copied it in from another project that was compiling correctly that it started to compile properly again.
This was a very frustrating problem and a lost of day of valuable project time chasing it down. I hope this helps others in the future.
I ran into this problem too:
https://developer.mbed.org/questions/77810/OS5-K64F-and-SDFileSystem-gets-online-co/#answer12519
Going forward, mbed wants you to forget SDFileSystem and use SDBlockDevice + FATFileSystem instead...
It is an onerous task converting to mbed CLI and not as convenient compared to the online compiler, but I made the change a couple weeks ago.
...kevin
