8 years, 11 months ago. This question has been closed. Reason: Duplicate question
MX25R serial flash file directory
I would like to use serial flash file directory method to create a file system for my mx25r(64Mb) serial Nor flash. I had interfaced using SPI communication between stm32l0 controller and Mx25R flash. I had created a file with size 1024 bytes but the problem is that i need to store large data.
Structure to store data variables
struct Data_Readings
int16_t ADXL_Readings[3];
float Lux_Reading;
float Temprature_Reading;
float Humidity_Reading;
float Pressure_Reading;
float Dew_Point;
Now I would like to create a file on serial flash file system of no size. After closing the file the size of the file can be taken in to consideration. Is there any way that I could get some help so that I could move forward or any suggestion would be really helpful. Thank you.
