8 years, 11 months ago.
OS5 K64F and SDFileSystem gets online compiler errors
It's been a wile since SDFileSystem has worked with os5 and the K64F. Last working version of os5 I'm aware of is way back in 2440:0993ae5. Any plans on fixing it? Or perhaps there is a replacement for SDFileSystem?
os5 example here:
https://developer.mbed.org/users/infinnovation/code/sd_test_5/
...kevin
Hi Kevin -
to use the filesystem with mbed OS 5 give this a try as the starting point. https://developer.mbed.org/teams/mbed-os-examples/code/mbed-os-example-fat-filesystem/ and make sure to see the readme about adding the sd backed driver. The example uses a RAM backed storage.
Here are the current docs for storage systems in general https://docs.mbed.com/docs/mbed-os-api-reference/en/latest/APIs/storage/storage_index/
I am going down the CLI path for the first time. With program mbed-os-examply-blinky, I get build errors with the GCC_ARM compiler. It complains (many times) that there is multiple instances of "main".
Memory map breakdown for built projects (values in Bytes):
| name | target | toolchain | static_ram | stack | heap | total_ram | total_flash |
Build successes:
* K64F::GCC_ARM::MBED-BUILD
Build skips:
* K64F::GCC_ARM::MBED-OS-FEATURES-FEATURE_LWIP-TESTS-MBEDMICRO-NET-TCP_PACKET_PRESSURE
* K64F::GCC_ARM::MBED-OS-FEATURES-FEATURE_LWIP-TESTS-MBEDMICRO-NET-TCP_PACKET_PRESSURE_PARALLEL
* K64F::GCC_ARM::MBED-OS-FEATURES-FEATURE_LWIP-TESTS-MBEDMICRO-NET-UDP_PACKET_PRESSURE
* K64F::GCC_ARM::MBED-OS-FEATURES-FEATURE_LWIP-TESTS-MBEDMICRO-NET-UDP_PACKET_PRESSURE_PARALLEL
* K64F::GCC_ARM::MBED-OS-FEATURES-TESTS-FILESYSTEM-FAT_FILESYSTEM
* K64F::GCC_ARM::MBED-OS-TESTS-MBED_DRIVERS-MEM_TRACE
* K64F::GCC_ARM::MBED-OS-TESTS-MBED_DRIVERS-STATS
* K64F::GCC_ARM::MBED-OS-TESTS-NETWORK-WIFI
Build failures:
* K64F::GCC_ARM::MBED-OS-FEATURES-FEATURE_LWIP-TESTS-MBEDMICRO-NET-CONNECTIVITY
Building project connectivity (K64F, GCC_ARM)
Scan: GCC_ARM
Scan: FEATURE_LWIP
Scan: FEATURE_STORAGE
Scan: connectivity
Compile [100.0%]: main.cpp
Link: connectivity
C:/Users/kevinb/mbed/mbed-os-example-blinky/BUILD/tests/K64F/GCC_ARM/main.o: In function `main':
main.cpp:(.text.startup.main+0x0): multiple definition of `main'
C:/Users/kevinb/mbed/mbed-os-example-blinky/BUILD/tests/K64F/GCC_ARM/./mbed-os/features/FEATURE_LWIP/TESTS/mbedmicro-net/connectivity/./main.o:main.cpp:(.text.startup.main+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
Update 24-Apr-2017:
I was able to get the FatFileSystem up over the weekend. Now searching how get the SD working again
Update 26-Apr-2017
SD up and running again
posted by 21 Apr 2017
Hi Banchao,
I gave up on SDFileSystem a long time ago. I now use FATFileSystem together with SDBlockDevice. These are now embedded into mbed-os. The calls are a little different, but it’s works very well.
...kevin
posted by Kevin Braun 04 Jan 2019
