8 years, 8 months ago.
FRDM-64F - USB & Serial link problem with W10
Hi, I am begining on this board and I have met a big issue at the very begining 1) When I connect the board to W10 (I have tried with different 2 PCs), the explorer appears with the board at the letter E: then it disapears after 30sec, then reappears... The fail.txt shows : "TIME OUT" If I generate a BIN (ex :mbed_blinkyK64F.bin) and I try tu put it into the board, nothing appens, then I see "SWD ERROR" into the fail.txt. I haven't the same behavior with a W7 PC - it works. I haven't seen any driver to install into W10. I have tried mbedWinSerial_16466.exe that is not recommended for W10 and it didn't work...
See this thread that may help - see the comments from Andrea Corrado:
https://developer.mbed.org/questions/973/SWD-error/
