9 years ago.
2 LED Blinky weird behaviour
Got an LPC800-Max board.
Instead of blue and green blinking after each other with a 1 second black gap, in the 1 second gap both leds are on (sequence is blue lightblue green lightblue in a loop) I can't explain this so please try to explain.. :/
DigitalOut ledB(LED1);
DigitalOut ledG(LED2);
ledB = 1;
wait(1);
ledB = 0;
wait(1);
ledG = 1;
wait(1);
ledG = 0;
wait(1);
9 years ago.
That sounds correct. This is your code but using "OFF" and "ON" to help explain..
#define OFF 1
#define ON 0
ledB = OFF;
wait(1);
ledB = ON;
wait(1);
ledG = OFF;
wait(1);
ledG = ON;
wait(1);
9 years ago.
Are your LED pins active low? It's quite common to wire LEDs up so that you output 0 to turn them on and 1 to turn them off.
