9 years, 1 month ago.
STM32F469 - How to write interrupts for lines 5-15? Do I need to start using a library with EXTI?
I'm trying to program interrupts for the STM32F469 Discovery Board. I have successfully managed to code it for pin A5 (PA_4), with the following setup code:
  1. define WASHER_SIGNAL_PIN GPIO_PIN_4
  2. define WASHER_SIGNAL_GPIO_PORT GPIOA
  3. define WASHER_SIGNAL_GPIO_CLK_ENABLE() HAL_RCC_GPIOA_CLK_ENABLE()
  4. define WASHER_SIGNAL_GPIO_CLK_DISABLE() HAL_RCC_GPIOA_CLK_DISABLE()
  5. define WASHER_SIGNAL_EXTI_IRQn EXTI4_IRQn
void EwBspConfigWasherPin( TPinCallback aPinCallback ) { GPIO_InitTypeDef GPIO_InitStructure;
/* Enable GPIOC clock */ WASHER_SIGNAL_GPIO_CLK_ENABLE();
/* Configure washer signal pin as input floating */ GPIO_InitStructure.Mode = GPIO_MODE_IT_RISING_FALLING; GPIO_InitStructure.Pull = GPIO_NOPULL; GPIO_InitStructure.Pin = WASHER_SIGNAL_PIN; HAL_GPIO_Init( WASHER_SIGNAL_GPIO_PORT, &GPIO_InitStructure );
/* Enable and set EXTI lines 0 Interrupt to the lowest priority */ HAL_NVIC_SetPriority( WASHER_SIGNAL_EXTI_IRQn, 8, 0 ); HAL_NVIC_EnableIRQ( WASHER_SIGNAL_EXTI_IRQn );
WasherCallback = aPinCallback; }
This uses the HAL GPIO Library. But how can I use interrupts on pins 5-15? Do I need to start using a new library with the EXTI commands? Where is this library if so? If seems that the EXTI and GPIO commands are similar (i.e. mode, trigger, pin etc).
Why don't you use the mbed HAL ?
For example:
InterruptIn extpin1(PA_4);
InterruptIn extpin2(PB_5);
All the GPIO and EXTI configuration are managed for you.
Well the reason is because I am using a GUI design software which doesn't use mbed HAL, so I am trying to use the same libraries that it uses, in order to interface with the GUI.
posted by James Elder 08 Mar 2017
