9 years, 1 month ago.
I2C Connection Problem
I'm trying to use I2C on a nucleo L476RG for comms with an LCD display
I'm using some simple I2C scanner code:
  1. include "mbed.h" I2C i2c(PB_9, PB_8); sda, scl Serial pc(USBTX, USBRX); tx, rx
int main() { pc.printf("RUN\r\n"); for(int i = 0; i < 128 ; i++) { i2c.start(); if(i2c.write(i << 1)) pc.printf("0x%x ACK \r\n",i); Send command string i2c.stop(); } }
I have pullups on both SDA and SCL (PB9 and PB8) at 2.2K as recommended but when running the program I get every I2C address back as ACK
Any help appreciated,
Andy
Hi Andy. Please use the <<code>> and <</code>> tags in the future to format your code for easier viewing.
include "mbed.h"
I2C i2c(PB_9, PB_8); //sda, scl
        i2c.start();
           // Send command string
         i2c.stop();
remove the i2c.start() and i2c.stop() calls. Be sure there is a common ground between your mbed board and the external LCD.
Test again and post your results.
https://developer.mbed.org/handbook/I2C
