9 years, 1 month ago.
Problem with UART serial read to return when CR is pressed
I am using Nucleo-F103RB. I am trying to implement a serial console with password input Below is my code
while(1)
char* ab;
myled = 1;
pc.printf("Test\n");
pc.printf("Enter the password: ");
///////pc.gets(ab,(sizeof(char)*256));
pc.scanf("%s",&ab);
pc.printf("%s ",ab);
if(strcmp(ab, "password")==0)
fun1();
else
f2();
wait(10);
My NooB question
1. I want the user to enter a password of unlimited length. Not the buffered one like gets(). ( I don't care about BoF atm) 2. How do i make sure that when they press enter it returns whatever the value? Should I use an array and check for /n ?
Thanks in advance
You may not care about buffer overflow but you still need a buffer to put the data in, you aren't allocating any memory at all to store the entered text in. Unless the initial value of ab just happens to be in the RAM area of the memory map you're not going to get anything meaningful.
What's wrong with the scanf method you were using? You said you didn't care about buffer overflows so that should work fine. If you want one character at a time then you can use getc().
Yes, check for /n. Also check for /r just in case their terminal is set to send /r/n for a new line. But if you are checking one character at a time there is no need to use an array, you can check each letter as you get it so there is no need to store it.
Fixed version of your code:
while(1)
char ab[1024]; // allocate 1024 bytes, you will overflow if they enter more than that.
myled = 1;
pc.scanf("%s",ab); // no need for the &, ab is already of type char *
fun1();
else
f2();
wait(10);
version using getc that is immune to buffer overflows.
// returns true if the correct password is entered.
bool checkPassword() {
const char *correctPassword = "password"; // the password to look for.
bool passwordCorrect = true; // track if there have been any errors
int characterPointer = 0; // current character to check.
int passwordLen = strlen(correctPassword); // length of the password.
char userEntry;
do {
userEntry = pc.getc(); // get the next character
if (characterPointer < passwordLen) { // if we aren't passed the end of the password
if ( userEntry != *(correctPassword + characterPointer) ) // check their entry against the letter characterPointer into the password
passwordCorrect = false; // if the letters don't match they got it wrong.
characterPointer++;
} while ( (userEntry != \n )&& (userEntry != \r )) // keep going until they hit enter
if (characterPointer != passwordLen) // if they entered the wrong number of letters then it must be wrong.
return false;
return passwordCorrect; // if the length was correct return whether any of the letters were wrong.
while(1)
myled = 1;
if(checkPassword())
fun1();
else
f2();
wait(10);
Not sure what you mean. The code you have does this already right? Your biggest problem is that you're not initializing the
posted by Jan Jongboom 03 Mar 2017abpointer so you're writing in uninitialized memory which will cause you big trouble. Change that line tochar ab[1024] = {0};.
