9 years, 1 month ago.
Do this board has any mbed client example
Do this board has any working examples that it can communicate with Device connector over Cellular.
The MultiConnect® Dragonfly offers developers an FCC and carrier certified solution that makes connecting sensors and other edge-of-network devices quick and easy.
I just got this board i am wondering if you can provide some working example to communicate with Device Connector over Cellular.
posted by Suraj Pal 21 Feb 2017
Suraj,
Unfortunately, we do not have an example for mbed device connector at this time. There is an example that supports a number of platforms and interfaces on GitHub.
https://github.com/ARMmbed/mbed-client-quickstart
You will run into issues today because our MTSAS library doesn't support mbed-os yet. We are working on that.
-Mike
Hi MIke,
When is it expected that the MTSAS library supports mbed-os?
Many thanks Adriaan
posted by Adriaan Kooderings Clemens 02 Mar 2017
We should have MTSAS updated to be compatible with mbed-os 5 by the end of Q2.
-Mike
posted by Mike Fiore 02 Mar 2017
As Mike said, no ready-made solution right now until the board runs mbed OS 5. However, we've used the Dragonfly with the AT firmware and a separate microcontroller which works well with mbed Device Connector. The driver is here: https://github.com/sarahmarshy/mtsas-driver.
Hey Jan, you mean that dragonfly board doesn't support OS 5 yet?
Correct, see Mike's comment (who works for Multitech).
posted by Jan Jongboom 22 Feb 2017
