9 years, 2 months ago.
FRDM-K64F UDPSocket methods return -3005 and -3003... why not 0 or -1?
Hi all,
I've implemented the below test app to try and identify the problem. Am i doing something wrong, because not only does UDP not broadcast, it also returns weird numbers. I'm using the K64F with mbed OS 5.3.4. Tried previous 5 versions, with same results.
main.cpp
#include "UDPSocket.h"
DigitalOut led1(LED1);
EthernetInterface eth;
UDPSocket udp;
Serial pc(USBTX, USBRX);
char msg[8] = "GusTest";
uint16_t port = 3648;
const char addr[16] = "255.255.255.255";
int i;
// main() runs in its own thread in the OS
// (note the calls to wait below for delays)
pc.baud(115200);
pc.printf("\r\nStarting...\r\n");
i = eth.connect();
pc.printf("\r\nConnect code %d IP is: %s\r\n",i, eth.get_ip_address());
i = udp.bind(addr, port);
pc.printf("\r\nBind code for %s on port %d = %d\r\n",addr, port, i);
i = udp.open(ð);
pc.printf("\r\nOpen code %d\r\n", i);
while (true) {
led1 = !led1;
i = udp.sendto(addr, port, msg, sizeof(msg));
pc.printf("\r\nSend Code %d\r\n", i);
wait(2);
Output
Starting... Connect code 0 IP is: xxx.xxx.xxx.xxx Bind code for 255.255.255.255 on port 3648 = -3005 Open code 0 Send Code -3003 Send Code -3003 Send Code -3003
Same problem here...
posted by yota news 03 Apr 2017
