9 years, 1 month ago.
Nordic nRF52-DK stops its serial communication with a linux pc
I used a windows pc with tera term for the serial communication until now (with online compiler). There everything was working fine. But i wanted to switch to Linux (arch) for the mbed cli. Compiling is working fine, but the connection to the serial port always quits after a first few transmission and the LED stops at its current condition.
I tested multiple Serial terminals in Linux (cat, screen, putty,picocom...) but everywhere the same behaviour. The "port" was always /dev/ttyACM0.
So I first thought the maybe my Linux configuration has some problems but i tested with an arduino under the same conditions and everything worked fine (9600 baud rate, 8 bits, 1 stop bit, no parity).
Now to the question: Is there a bug with the mbed library or the nrf52-DK using the serial port? And is there a workaround?
Greetings, Chris
Here the simple code example i used to test the "bug":
DigitalOut led1(LED1);
    int counter = 0;
    while (true) {
        pc.printf("test %d \n", counter);
        counter++;
        led1 = !led1;
        Thread::wait(500);
The nRF52 Development Kit is a single-board development kit for Bluetooth Smart, ANT and 2.4GHz proprietary applications using the nRF52 Series SoC. This kit supports both development for nRF52832 SoCs.
Just found the following resolution via a Google search:
https://devzone.nordicsemi.com/question/91854/mbed-os-serial-port-hang/
https://github.com/ARMmbed/mbed-os-example-ble/issues/25
Yeah, adding the following mbed_app.json to the root of your project helps:
    "target_overrides": {
        "NRF52_DK": {
            "target.uart_hwfc": 0
Thanks for your help :-)
posted by Christoph Groß 20 Jan 2017
By default nRF52-Dk target use hardware flow control on serial port (involved RTS/CTS signals) - so the described behaviour is not a bug. As was answered above: it is possible to turn of flow control on DK firmware or turn it on in PC terminal.
