9 years, 3 months ago.
Why program start after plug in USB cable ?
Hello, I have very simple program but there is a problem because the program starts only after plug in USB cable to board. After unplug USB from board the program is stopped. Could You help me with this issue ?
#include "USBSerial.h"
#include "MODSERIAL/MODSERIAL.h"
DigitalOut LedStatus(P0_13);
DigitalOut LedBattery(P0_14);
USBSerial usb;
MODSERIAL uart(P0_19, P0_18);
InterruptIn timepulse(P0_17);
void rxCallback(MODSERIAL_IRQ_INFO *q) {
    LedBattery = !LedBattery;
    usb.putc(uart.getc());
void toogle(){
    LedStatus = !LedStatus;
int main(){
   // int c = 'A';
    timepulse.rise(&toogle);
    uart.baud(9600);
 //   uart.attach(&txCallback, MODSERIAL::TxIrq);
    uart.attach(&rxCallback, MODSERIAL::RxIrq);
 //   uart.attach(&txEmpty, MODSERIAL::TxEmpty);
     while(1){
Please notice that in case you create a USBSerial object with no parameters passed to the constructor then by default it blocks the program until a USB serial device has been found. To turn off blocking try to create a USBSerial object as follows:
USBSerial   usb(0x1f00, 0x2012, 0x0001,  false);
Hello, my board is powered by battery. I think circuit is ok but i am not sure. please see my schematic.
https://drive.google.com/uc?id=0B_OOjYgNKTK-THJuNVpjM1pKLVE&export=download
posted by Peter Augustin 14 Dec 2016
Yes, it seems OK. I did not notice that you use USBSerial so my first thought was that it could be power supply issue.
posted by Zoltan Hudak 14 Dec 2016
i made a little changes in my code and i do not know why USBSerial again is blocking my code after disconnect USB cable.
code
#include "MODSERIAL.h"
static const uint8_t VCELL_MSB =            0x02; //Read only
static const uint8_t VCELL_LSB =            0x03; //Read only
static const uint8_t SOC_MSB =              0x04; //Read only
static const uint8_t SOC_LSB =              0x05; //Read only
static const uint8_t MODE_MSB =             0x06; //Write only
static const uint8_t MODE_LSB =             0x07; //Write only
static const uint8_t VERSION_MSB =          0x08; //Read only
static const uint8_t VERSION_LSB =          0x09; //Read only
static const uint8_t CONFIG_MSB =           0x0C; //Read/write
static const uint8_t CONFIG_LSB =           0x0D; //Read/write
static const uint8_t COMMAND_MSB =          0xFE; //Write only
static const uint8_t COMMAND_LSB =          0xFF; //Write only
static const uint16_t RST_CODE =            0x5400; //reset code for COMMAND 16-bit register
static const uint16_t QUICKSTART =          0x4000;
//Levels
static const float DIV_VCELL =              1.25e-3; //1.25 mV/level
static const float DIV_SOC =                0.00390625; //1/256% / level
I2C i2c(P0_5, P0_4);
//MODSERIAL uart(P0_19, P0_18);
Serial uart(P0_19, P0_18);
InterruptIn GPS_fix(P0_17);
//void Rx_interrupt(MODSERIAL_IRQ_INFO *q)
void Rx_interrupt()
void toogle()
int SOC()
    char cmd[1];
    char data_read[1];
    __disable_irq();
    cmd[0] = 0x04;
    i2c.write(108, cmd, 1);
    i2c.read(109, data_read, 1);
    __enable_irq();
    return data_read[0];
    char cmd[2];
    i2c.frequency(400000);
    cmd[0] = 0x00;
    cmd[1] = 0x54;
    i2c.write(108, cmd, 2);
    cmd[0] = 0x4000;
    GPS_fix.rise(&toogle);
    uart.baud(9600);
    uart.attach(&Rx_interrupt, Serial::RxIrq);
        wait(1);
        usb.printf("SOC: %d\r\n", SOC());
posted by Peter Augustin 24 Dec 2016
